Speedo cable sticking?
Old Nov 19, 2004 | 09:35 AM
killain's Avatar
killain
Oldtimer
Default Speedo cable sticking?
How do I go about greasing the speedometer cable on my 79 vette. Does it come out from below or from behind the dash? Thanks.
Old Nov 19, 2004 | 09:39 AM
L82-JWS's Avatar
L82-JWS
you can reach up under dash, and 'unclip' cable from the head of speedo. you can then apply lube from there.....
Old Nov 19, 2004 | 09:48 AM
75 Hot One's Avatar
75 Hot One
In '75 there was a major problem with this- speedometer needle jumped all over the place. No amount of cable lube corrected it. Cause was a problem with the transmission driven gear. Don't know if this problem was resolved by '79 but, if cable doesn't correct the problem, look at the driven gear- easily replaceable by disconnecting the speedo cable at the transmission.
Old Nov 19, 2004 | 11:53 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I bought the special grease tool from Mid-America. You just remove the ends, screw onto the fitting and then it has a grease fitting so you can pump grease into the cable. Doing this regularly helps eliminate the speedo needle bounce.
Old Nov 19, 2004 | 04:46 PM
killain's Avatar
killain
Oldtimer
Thanks, this what I needed to know.
To Speedo cable sticking?
