I'm guessing there is no difference in the frame itself, especially in the engine area. However, you will have to replace the radiator since the SB ones are smaller. Also, most small block accessories probably won't fit the BB (fuel pump, fan, pulleys, etc.), but you probably knew that already. Bellhousing would also need to be changed and you'll probably have to beef up the transmission also. But this type of work is what makes things interesting, right?
The motor will drop right in. No need to change the bellhousing as they are the same. You will be putting on new fuel pump and water pump anyway. The brackets for the acc. will be different and a new rad will be needed. Probably a newset of front springs won't hurt either. Many here have converted their post 74 cars to big blocks. Not a real big deal to do. Just costs $$$ as does everything on a Vette.
Where are you located? Depending on the state you live in, you may not be able to do anything (and I do mean ANYTHING!) due to emissions testing regulations...
I agreee with Page 62....If your looking for a car to Mod...get a 73-74. I see this emmissions thing only getting better and as those cars were pre Catalytic converter most all of the new laws will not apply.
I am in Tempe Arizona but I think I can get around the emissions thing by registering it at my address outside of Maricopa county.
Hello,
I thought you might be in Arizona with the name LouAZ.
If you are going to rebuild or modify the engine, then the smog laws of the state will prevail. You said you could register it outside of Maricopa county so that probably puts you near Phoenix, Tempe, Mesa, etc.
I think the way it works in Arizona is that if the car is registered in Maricopa county (Phx, Tempe, Mesa etc...) or Tucson then all vehicles after 1967 need to pass emissions. However, if you register it outside of Maricopa county then you can get a waiver. I do live in Tempe but also have an address in the northern part of the state that I plan to use.
GM sells a nice 454HO for ~$4700 from GM Parts Direct. Consider it when you pick your motor. DeWitts can sell you the radiator... Sounds like a fun project! Enjoy!
