one way check valve in brake bleeders
i saw these in the new echlers , c-3 catalog,,, says there for 1 man brake bleeding.. has a check valve inside of bleeder so air and fluid get out when you press pedal ,, but when you release pedal no air gets sucked back in the line,,, was wondering if any had tried these,, and if so how well they work,,,
They work great. Had them on my C4 and have put them on my 69. I used clear vinyl tubing that slipped over the bleeder and ran the tube to a water bottle with a "sport" type cap. Knock the center out of the cap and fit the tube in the hole. Use enought tubing to allow you to run to the farthest caliper and place the bottle the the floor by the driver. That way you can watch for bubbles and/or clean fluid as you pump the brake pedal. Just don't let the master cylinder go dry. I can bleed the brakes by myself in about thirty minutes and that includes removing the wheels.
St. Jude Donor '05-'08
http://cgi.ebay.com/ebaymotors/ws/eB...category=33563
These should work just as well as ones from mid america and corvette central right?
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Sorry, these are the right ones for our years. Different size.
I use them on my car and they have worked great. Just like cart3113, I used them with a vinyl tube and a jar. Very easy to use.
PS. Speedbleeders are something that you can buy at your local Discount Auto parts store. I've seen them there, just not the right size, so they may have to order them but at least you wouldn't have to pay postage and handling.
That's a nice price - $6/pr.
I use speed bleeders, or earls slow bleeders (same idea) on all of my vehicles... I'll never do another brake job without a set handy if they aren't already in the calipers...
Senior Member since 1492
Originally Posted by NHvette
You'll need more than 4. I think it's (8) bleeders for our 4 calipers.
3 on each rear caliper and one on each front. I just put them on this summer.
1 Post
Originally Posted by Gordonm
Called speed bleeders. SOme like them I have never used them. They have been around for a while. Good idea, I just made my own pressure bleeder.
did you post pictures?? put them on the home made tools thread with a parts list.... i'll dig the thread up i have something to add anyway...
St. Jude Donor '07
Originally Posted by BigBadOrange
Do you have a design for the pressure bleeder? I would love to have one in my garage.
Originally Posted by greyghost79
i bought some but the threads seemed larger than the stock bleeders. are there different size speed bleeders?
