Oil Leak
Old Nov 20, 2004 | 09:43 PM
wogs73's Avatar
wogs73
Default Oil Leak
This is the second time I've replaced the oil pan gasket and it still leaks at the front seal. I even coated the new seal with rtv and ran a bead on the pan also. Now I'm thinking I need to take the cheap chrome timing cover off and replace it because that's the only thing left that I can think of that may be the cause. Any thoughts would be greatly appreciated!
Old Nov 20, 2004 | 09:46 PM
comp's Avatar
comp
balancer smooth ????
Old Nov 20, 2004 | 09:48 PM
jcswm's Avatar
jcswm
are you sure it's not the front crank seal leaking?????
Old Nov 20, 2004 | 09:49 PM
wogs73's Avatar
wogs73
It's not leaking out of the balance seal but the front of the pan, sorry I wasn't more clear
To Oil Leak
