St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Right click on the photo you want to post as a pic and copy its location. Then just above the reply box is a a button that looks like mountains with a sun in it, click that button. A box will pop up paste in that pop up the location of the photo you want to show and hit ok. After you type your reply click submit reply. If you did it right the photo will appear in the post. Give it shot.
I did just as you described but all I see on the thread are little boxs with a red X that should be a picture - Help
Looks like they are working in this thread. Only one thing, you linked up to some of the thumbnails. Try getting the full size image property and you will be set.
One more thing, I think Corz suggested photobucket, with that one there is no approval waiting like the corvette forums webserver. I use both.
Thanks - I finally figured it out and got the full size pic's posted in the thread.
