Need help with tuning mystery!?
ENGINE; 1971 454 rebuilt (I didn't rebuild it so I haven't much knowledge what's inside except TRW pistons(suppose to be 10.5-1) and small cam(only lopes when cold) had Q-jet now has holley 4175/650cfm spread bore double pumper/Qjet replacement. Stock points distributor.
PROBLEM; With timing set at 35* total it starts to "break up" sputter at about 4300rpm. It only does this under WOT. It seems that as soon as I get into the secondaries it starts missing/sputtering. If back the timing off to about 24*total it does it much worse and at a lower rpm. If I floor it from a dead stop it takes a while to do it(until it reaches 4300rpm) If I am rolling in 2nd (auto) and downshift into first it immediatly does it which leads me away from fuel delivery problems.?
What I Have Done:
1 Changed carbs/ still does it
2 Tried jetting the holley way rich on the secondaries (94's) not much change
3 Tried jetting lean (62) severe popping/backfiring out the carb
4 Changed plugs (had 42's now has 43's)
5 Changed cap and rotor, points and condenser. Dwell okay
6 Changed coil
7 Checked fuel filter in carb
8 Replaced all rubber fuel lines thinking one was collapsing
9 Remove sock from fuel line pickup in tank
10 Drilled hole in dist. cap to verify that rotor was directly underneath cap/wire contact when firing(with timing light).
11. Checked balancer to see if ring slipped although it shouldn't make a difference as it pings at 35* with the gas I have in it now so it should be pretty close either way.
12. Remove air filter
13. plug wires are fairly new and don't have any burn marks and are the steel braided type(on the outside) if that makes any difference.
It is strange that it only seems to do it when I open the secondaries even though I can open them at a lower rpm for a long time and it runs great. When I retard it the same thing happens only at a lower rpm but only when I start getting into the throttle (secondaries again)?
thoughts I have right now are.
Could the timing chain stretch cause this(engine only has about 2000 miles on it so I was told)? again I can't see it losing more that a couple of degrees?
Could the cam be indexed/off due to machine work and would it cause this? every engine I put together I degreed. I couldn't see a couple of degrees retarded making this happen.
I thought maybe cam lobes but it runs great up to that rpm and it is definatly not coming out the intake. It is in the exhaust if anything
Any ideas? Hopefully not as severe as what I am thinking. I hope not to tear into the engine. If I have to do that I guess I will just take it out and start over. If who ever put the engine together can't install the cam right then who knows what else has/hasn't been done?
I have my fingers crossed
I didn't think fuel pressure/volume because I can load it on the freeway/steep grade at WOT for ever without any missing. Also if in second and I down shift it immediatly does it. I would thing the fuel in the bowl would feed it for at least second.?
Cam I was told is hydraulic.
Will try adjusting valves after the plug wires.
Would changing the ignition timing effect this?
