Bending new fuel lines.
Discovered it was too slopy because the bender was made to fit 3/8" i.d. tubing and not tight enough for 3/8" o.d. tubing that i use. Not to knock HF as the strength and finish was good enough for me and would have been fine for larger tube. I dug up my old General tri size bender and it worked great. Tight 180* bends easily.I've found that some brake line is better quality/for fuel line use than others. After several attemps at a 90* bend with some green colored stuff from Auto Zone i found it continued to flatten instead of bend round as needed.
Bought some 3/8" brake line from NAPA and it bent up just fine.So i updated my pix in my sig to show off my new lines. Or use this link http://www.cardomain.com/id/cardo0. I built a return line by drilling, taping, JB Welded in a brass bushing (and tee) into the Qjet inlet (thats a lars rebuilt Qjet BTW
). Both lines are covered with Home Depot plumbing insulation glued on with 3M weatherstrip adhesive. The return has a 0.040" orifice installed to act as recirc to maintain fresh/cool fuel and constant press and connects to the old vapor return line to fuel tank. The new Carter fuel pump didn't have a vapor return fitting and now i won't need one.Pix don't show much of the polished Edelbrock wtr pmp but its a great match for the polished Edel Performer Air-Gap.
I think i have it the way i want it for now and will see how it works out. BTW that can on the right side of installed inlet tee (no not the fuel filter) is my Holley electric fuel press sensor. I should know what my inlet press is at any time from the drivers seat.
Just have to fix the oil in drivers wtr jacket crisis first.
cardo0
That is the page that I was talking about...
I'll have to save the corvettefaq.com page... again! Keep losing it!
I'll have to pickup some tv cable or something...
Maybe somebody else knows! Its got a bunch of great articles!
That special filter was'nt cheap (but not really too expensive either). At less than $5 for 5 ft of 3/8" steel brake line i could afford plenty of mistakes. I'm think'n the lars design might be great for a high fuel pressure application and worth the expense then. I submitted to using 2 short pieces of flex in a visable location. That steel line by lars is a great piece but i'm a bit cheaper and for my plans the 2 short pieces of flex will be just fine as thier both visable and not in contact with any metal. And i may change my fuel lines again when i install my A/C compressor. I had planned to use a larger FRAM filter but submitted here to for lack of a good brace/bracket for the heavy filter housing. And the FRAM has 3/8" NPT ports that will allow hard line plumbing entirely. I need to install the compressor first
to sort things out.Those are some neat homemade benders
but now i feel spoiled with my General tri size.
It works like a hand tool should - fixes things right instead of creating more work/problems. BTW there's an O-ring sealing the sending unit to bottom of fuel tank - at least in my '74.
Good night all.
cardo0
So what i learned works best was to cut tubing with a hack saw then file square to clean end. This left the metal soft enough to double flare. And to replace a bad/unwanted flare trim far enough away to remove the hardened steel end. BTW i stumbled onto the new mini-hacksaws (Home Depot, etc.) that work great for small work and fit in the tool box. And for the rubber flex tubing ends i was able to bulb the end by just starting a double flair - not finishing/completing the die stroke/press. Works great to seal the tube with a clamp behind the bulb and looks like commercial made fuel line.
Good luck and have fun bending up ur car (lines).
cardo0
