Rear leaf spring ???
Old Nov 21, 2004 | 11:19 PM
Not2New72's Avatar
Not2New72
Default Rear leaf spring ???
Evening all...Today I found that my rear leaf springs are slipping to the side. The spring thats second from the bottom only has 3/8' left on the bottom spring. Are there supposed to be clamps out near the ends that hold them together?
Roy
Edit...they're twisting
Old Nov 21, 2004 | 11:43 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
They should not move. You may want to post a photo so everybody can clearly see what the problem is.
I'd check the four bolts that hold the spring to the differential - maybe the differential cover is cracked ???
Trailing arms could be loose ....
Just lift the rear and check everything that you can see - there should not be a clamp on the spring .
Old Nov 21, 2004 | 11:47 PM
Not2New72's Avatar
Not2New72
My photos are coming (pending approval). I didn't look closely at the rear diff for cracks. I'll post again when I have pics.
Roy
Old Nov 22, 2004 | 10:11 AM
Not2New72's Avatar
Not2New72
The spring pics have been added to the gallery. What you think?
http://forums.corvetteforum.com/phot...hp?photo=24148
http://forums.corvetteforum.com/phot...hp?photo=24150
Old Nov 22, 2004 | 10:58 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
See this happen a lot. I would fix it immediately. Can't really say one thing causes this to happen. I would check the spring width and rear end cover. Someone may have replaced the spring at one time and used the wrong one or they could have replaced the cover at one time and replaced it with the wrong one. 63-77 use a 2 1/4" spring and the 78-79 cars had a 2 1/2" spring. When you pull the spring off check the cover for cracks, as mentioned above, and the bolt holes.
When you install a new or rebuilt spring and you run the bolts back up into the cover, run them up a little bit at a time. Sort of lile you would do with tire lug nuts. This will help in the prevention of cracking the cover.
Old Nov 22, 2004 | 11:06 AM
1971corvette's Avatar
1971corvette
Just from the looks of it, it looks like the rust build up is letting the springs move around.
and i agree with van steel
That is one ugly spring.
I would have to change that,even if you would take it apart to clean it and put new spring liner in,this won't take care of a worn out spring.
Buy a new one
Old Nov 22, 2004 | 12:52 PM
Van Steel's Avatar
Van Steel
If you do rebuild that spring, take it to a local spring shop and have them re-arch it for you. They can tell you if they spring is worth saving or not. Spring liners can be expensive.
Old Nov 22, 2004 | 02:04 PM
mayberg's Avatar
mayberg
I had zero luck with re-arching a leaf spring. Eaton Spring makes a great steel replacement spring - looks pretty much exactly like the original. Check 'em out here . I got one, and it's been working great.
Of course, if you'd rather change to a fiberglass mono spring, there's lots of others that can give advice on that.
Old Nov 22, 2004 | 03:12 PM
NHvette's Avatar
NHvette
Need good pics of the four bolts/cover that hold the spring in the center.
Old Nov 22, 2004 | 03:30 PM
Frankenvette's Avatar
Frankenvette
Roy
Both my installed spring and my replacement spring have clamps on each end that help prevent slipping.
Old Nov 23, 2004 | 08:29 AM
greyghost79's Avatar
greyghost79
i've got a 79. had the same problem. had springs re-aligned several times. within a week or so they twisted again. finally just replaced with a vbp composite spring. no problems since.
To Rear leaf spring ???
