I am in the process of installing vortec heads on my 77. I find that the existing water temperature sensor is a larger thread than the tap in the vortec heads and so cannot be screwed into the heads. Does anyone know of a compatible sensor that will fit the vortec head tap?
I have vortec's on my 78. You must use the matching sender for your gauge. For the time I have my sender in the thermostat housing. You can also put it in the intake manifold next to the thermostat housing. I would like to put it in the head but like you said the head has a 3/8" NPT while the sender is 1/2" NPT. It's easy to reduce the opening with fitting but can't seem to fine fittings to make it larger.
I have Vortec heads on my 77. I also have an Edelbrock Performer intake. I installed the temp sender in the intake manifold, neat the t-stat housing. Seems to work OK.
I had the same problem. I went to the hardware store, ACE, and found an adapter that worked. I just tried all the adapters they had on the shelf until I found one that worked. I think I had to cut off the end of the adapter that threaded into the cylinder to ensure that the temp sensor had access to water flow. You want to only use the sending unit that is calibrated to your temp gauge.
Ran into this myself. I used a die grinder to hog the hole out to the tap drill size then ran a pipe tap in the hole. You could purchase the correct tap drill as an alternative. The stock senders fit fine now. It sounds worse than it was. The hole does not need to be opened up much at all. Once all the original threads are gone, you are about there.
Bought the used pipe tap on ebay for a few bucks and ran it into the hole. If you have ever done any port work at home this is not difficult at all.
A machine shop could do this for you as well if you do not trust your workmanship.
