Better degreaser than GUNK???
Old Nov 22, 2004 | 09:54 PM
Vette X 3's Avatar
Vette X 3
Default Better degreaser than GUNK???
Trying to remove 23 years of grease and crud from the under-carriage of my '82. It's thick! Car is up on jack stands for the winter so steam cleaning won't be a possibility although I have one I can borrow. Laying under the car with a putty knife, I went through 12 cans of foam gunk and 5 cans of brake cleaner. Got dirty-got "high" off brake cleaner fumes, but crud is still there. Especially in hard to reach crevices. Heard oven cleaner works but eats paint. Anybody got a great recommendation for something that really soaks in an lifts the crud so it can be rinsed away?
Bill
Old Nov 22, 2004 | 09:57 PM
Bryan8412_2's Avatar
Bryan8412_2
Not sure if I know of any gunk removers but you may want to think about taking the body off and sandblasting. It'll make it look like new!
Bry
Old Nov 22, 2004 | 10:51 PM
bn7035's Avatar
bn7035
I used Simple Green. It still takes a brush, putty knife, and a little work.
Old Nov 22, 2004 | 10:54 PM
Xx Grave's Avatar
Xx Grave
i did it with a 4 inch paint scraper, and a regular razor blade scraper. Use Super Clean. It is the best thing ive used, although really harsh on the lungs....
Old Nov 22, 2004 | 10:58 PM
Retro78's Avatar
Retro78
I found that the job went faster by starting dry....just wire brushes and puddy knifes. The more you can take off dry, the better. Then I used several applications of de-greasers with nylon brushes, then finished up with SOS pads. Final product was great.
Old Nov 22, 2004 | 11:00 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
That stuff won't come off without mussles, wire brush, scraper and again a brush. The engine cleaner and degreaser from AutoZone or Discount Auto are not bad at all, you just have to brush it in and scrape.....
It took 23 years to build up, can't just spray and see it going away....
Get a fan for the fumes, the brake cleaner is terrible
Old Nov 22, 2004 | 11:03 PM
Hitch's Avatar
Hitch
Greased Lightening is the best degreaser that I have found you can get it at Lowes OR Home Depot. Dave..
Old Nov 22, 2004 | 11:57 PM
Glassbowtie77's Avatar
Glassbowtie77
Castrol Super Clean is the best stuff I've ever used. It really dissolves the gease and grime very easily with very little elbow grease needed.The only drawback is the fumes, they can be pretty hard on the lungs, you must use it in a well ventilated area and stay upwind of it when spraying it. Nothing I've ever used cleans like this stuff, it is amazing.
Old Nov 23, 2004 | 12:06 AM
comp's Avatar
comp
scrape, brush,,etc.... 1/3 Dawn and 2/3 water .. Cheap and then you are to the detail point ( mix into a spray bottle,let set)
Old Nov 23, 2004 | 01:55 AM
Schmucker's Avatar
Schmucker
I agree. My mom sells it at her hardware store (her supplier is HWI - Do It Best) and it is the only thing that will get the butter out of the carpets at work (movie theatre).
Old Nov 23, 2004 | 08:06 AM
markdtn's Avatar
markdtn
Old Nov 23, 2004 | 09:10 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
[IMG][/IMG]
i used simple green first and then greased lighting, i really it took me about 6 hours and three differnet days to fininsh, wish i had only used greased lighting. it took the areas that simple green couldn't get and "melted them the first time" i used a pressure washer with hot water...
[IMG][/IMG]
i cleaned under there again and then stared to brush on my paint, wait untill you start painting, i must have 13 hours in it to already and it needs another 2 or 3 hours.. good luck!
Old Nov 23, 2004 | 10:05 AM
COMMANDER370's Avatar
COMMANDER370
I used a de-greaser from Sam's.looks purple like the Castrol and smells the same,but is 5.25 for 5 quarts which is a lot cheaper than the Castrol.
Old Nov 23, 2004 | 10:32 AM
Hvymtlc5's Avatar
Hvymtlc5
I just did the same on my 78. After numerous cans of Gunk, I used a power washer with the "pencil" beam water stream. Blew the thick clumped grease away in no time. Worked good too for taking off old engine bay paint that the previous owner had gotten all over stuff that wasn't supposed to be painted black.......
Old Nov 23, 2004 | 12:13 PM
1978shark's Avatar
1978shark
Not to hi-jack this post but Bob77, how did you go about getting your car on the jackstands? Did you raise one side at a time or front to back? One click per jackstand per side? Just curious.
Old Nov 23, 2004 | 12:51 PM
bobs77vet's Avatar
bobs77vet
long frame jack- 3' lift capacity, huge top quality jack stands, and an odd number of jackings from the center of the frame rails...1 drivers side to 14", 2 pass side to 18", 3 drivers side to 18" etc. etc. etc. you have to do it incrementally... and same with lowering it
Old Nov 23, 2004 | 01:54 PM
LOTAHP's Avatar
LOTAHP
Muratic Acid diluted with water will eat the chit right up. Hose off immediatly.
To Better degreaser than GUNK???
Old Nov 23, 2004 | 02:45 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Gunk used to be a good product but it's junk now... Any of the purple stuff is better.. I guess the folks at gunk didn't think we'd notice....
Old Nov 23, 2004 | 03:23 PM
comp's Avatar
comp
it used to be flammable (if it hit open flame)
Hvymtlc5's Avatar
Hvymtlc5
Saw something in this thread that concerns me...what is the deal with the "precision" jacking of the car? If I don't do this will something torque or crack? I've just been jacking the car up anywhere there is support ........to do what I need to do. Never heard this before. If it is all precautionary well, that's ok too.
