Carb Linkage
Old Nov 23, 2004 | 06:47 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default Carb Linkage
What is the best type of fastener to connect my throttle cable to my carb?
Les
Old Nov 23, 2004 | 09:29 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Les
i seem to recall you also have a speed demon.. right? Edelbrock makes a throttle stud with a "cotter pin" for retaining the cable that fits in the linkage hole for about $5 from a local speed shop, thats what i'm using.
Old Nov 23, 2004 | 09:36 AM
comp's Avatar
comp
and maybe a wave washer
Old Nov 23, 2004 | 10:00 AM
AGVI's Avatar
AGVI
comp - What's a 'wave washer'??
Bob - Do you have a part# for that?
Thanks, Les
Old Nov 23, 2004 | 10:05 AM
markdtn's Avatar
markdtn
If your junkyard has any late 70s cars you can find some GM with removable cable studs. Probably easiest to just buy a new one though.
Old Nov 23, 2004 | 10:42 AM
AGVI's Avatar
AGVI
ok, what about Edelbrock part #'s
8018
and 9141
Will these work?
Old Nov 23, 2004 | 12:59 PM
bobs77vet's Avatar
bobs77vet
Thanks, Les
i'll check at home tonight
check out WWW.SDPC2000.com
part number H20-38, this was my first choice until i saw the other one at the speed shop
EDIT
looks like they have the sizes 1/4 or 7/32 backwards inthe SDPC catalog
http://www.sdpc2000.com/catalog/1422...ottle-Stud.htm
Old Nov 23, 2004 | 01:38 PM
AGVI's Avatar
AGVI
Why did you choose the one at the speed shop over the one from Scoggin Dickey?
Also, will H20-40 work for my TH350?
Les
Old Nov 23, 2004 | 01:43 PM
bobs77vet's Avatar
bobs77vet
Les
only because it was $4.95 and right in front of me. i'm in the process of putting in a 700r4 so can't help on that one..
Old Nov 23, 2004 | 08:23 PM
AGVI's Avatar
AGVI
Do I need 1/4 or 7/32?
2038 or 2037?
Also, anyone know which trans kickdown stud do I need?
2040??
These are Holley part #'s
Les
Old Nov 23, 2004 | 08:50 PM
bobs77vet's Avatar
bobs77vet
this is what i'm going to use i'll go measure the diameters after i post this
[IMG][/IMG]
EDIT: it looks likes it 3/16 when i measured it??? my carb has one on now that a friend gave me so i can't measure the hole until i take it out. looks like the nut is the same size though...
To Carb Linkage
