torque on alum heads
Old Nov 23, 2004 | 03:46 PM
TTop Tony's Avatar
TTop Tony
Default torque on alum heads
Anybody know what torque setting I should use for my edelbrock aluminum haeds. I can't seem to find any actual numbers in any of my books. Any help would be appreciated.
Old Nov 23, 2004 | 03:56 PM
grayhook's Avatar
grayhook
just installed holley sys. max setup with alum. heads. thay say 65 ftlb...start at 35ftlb then 50 then 65....
dont know if edelbrock is same so you may want to call'm
good luck!
Old Nov 23, 2004 | 04:02 PM
Fevre's Avatar
Fevre
Believe with my trick flow's it is 35 then 55 then 70, done in steps. They seem to have removed the instructions from their website so I cannot 100% confirm it.
Old Nov 23, 2004 | 04:18 PM
Fevre's Avatar
Fevre
Bolt torq is listed on this spec page, looks to be either 65 or 70 depending on the head. Do it in stages although it does not state it, follow any of the head bolt tightening pattern diagrams for SBC, should be all the same.
http://edelbrock.com/automotive/head_flownumbers2.html
SteveG75's Avatar
SteveG75
Did Edelbrock not give you instructions? I have the PDF for the small block RPM's at home or you can get it from their website. I do believe that Grayhook is right off the top of my head. 35-50-65
Old Nov 23, 2004 | 04:22 PM
TTop Tony's Avatar
TTop Tony
I bought the heads used steve but I'll look on there website to double check. oops looks like Fevre found it for me, Thanks Fevre! The haynes did say to do it in steps and gave the sequence but no ft lb numbers. Thanks guys
Old Nov 23, 2004 | 05:42 PM
SteveG75's Avatar
SteveG75
40-55-65 per the PDF. Also recommends some good head gaskets. I used the Felpro 1003's when I assembled mine. I'll send you the PDF, its only 50k.
Old Nov 23, 2004 | 06:12 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
seems i remember the lowest row of bolts are supposed to be 5 ft/lbs less than the rest.
Old Nov 23, 2004 | 11:33 PM
71coupe's Avatar
71coupe
Felpro has some good advice:
http://www.federal-mogul.com/cda/con...9_7465,00.html
There is also an alternate procedure to retorque after they have been fully torqued down. You go back to bolt 1 & loosen it to zero torque, then pull it back up to full torque in one smooth movement. Continue this on all of the bolts. This helps lessen the side pulling of the gasket, and it's also the procedure if it's not possible to re-torque after the initial runup. I did that procedure.
To torque on alum heads
