hand cleaner
Old Nov 23, 2004 | 05:16 PM
terry82's Avatar
terry82
Default hand cleaner
i need to buy some new hand cleaner .what are you guys using?
Old Nov 23, 2004 | 05:20 PM
Gordonm's Avatar
Gordonm
Fast Orange.
Old Nov 23, 2004 | 05:22 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Gordonm
Fast Orange.
This is all I use. I don't like GOJO at all. It leaves some greasy residue that you have to wipe off anyway after you have washed your hands. Might as well not have washed your hands. Fast Orange smells better also.
Old Nov 23, 2004 | 05:24 PM
Fevre's Avatar
Fevre
Fast Orange.
I also started wearing some nitrile gloves, I hated them at first but once I got use to them it is nice not having to scrub dirt out of the fingers nails.
Old Nov 23, 2004 | 05:32 PM
comp's Avatar
comp
Dawn,,, cheap azzzz FastOrange
Old Nov 23, 2004 | 05:45 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Fast orange, and when thats out, Palmolive
Old Nov 23, 2004 | 05:47 PM
Twin_Turbo's Avatar
Twin_Turbo
Belt sander
Old Nov 23, 2004 | 05:54 PM
Lotus76's Avatar
Lotus76
Try this!!!
Super Tough Hand Scrub. This is by far the best Professional Formula hand cleaner available!
I had them send me a free sample. This stuff is great!
go to this link http://www.handscrub.com/
Southwest Commerical Products Inc
800-227-6994
www.handscrub.com
Product Benefits
America’s largest corporations rely on “Super Tough”
We use detergents to clean instead of solvents. Solvents dry your skin, and no amount of skin softener can change mineral spirits into a good hand cleaner. Save the solvents to clean your auto parts!
We balance 3 forms of energy to remove a stain (chemical/thermal/physical energy). Warm water is recommnded to provide the thermal energy. Our detergents provide the chemical energy and our ground plastic scrubbers provide the physical energy.
This is the quickest and cleanest rinsing hand cleaner on the market. Leaving no oily residue or strong odors. It will even remove gasoline and fish odors.
Tired of your “Hoho” hand cleaner melting in the summer months? Ours never will. Super Tough has a shelf life of 5 years.
With a pH of 7, this balanced formulation is easy on the skin, and we use non-greasy skin moisturizers.
“Super Tough” is the best choice to remove any stain with a high count of imbedded particulate.
Our detergents break down the “oil vs water” properties of a stain to keep it from sticking to the sink and internal plumbing. It cleans your pipes every time you wash your hands. Grease is completely emulsified.
Solvents have a low flash point because they are derived from petroleum. Local fire departments may require special storage compartments for solvent-based cleaners.
Our goal is to provide the most effective cleaner without the excessive skin irritation which results from using inferior solvent-based products.
This is a professional-grade, full strength hand cleaner.
Old Nov 23, 2004 | 07:25 PM
ZD75blue's Avatar
ZD75blue
I spray em down with purple power. I've got a spray bottle of water and a spray bottle of purple power in the garage. Spray down, rub the hands down... spray off with water. Works like a charm!
Does a GREAT job of taking off the really hard stuff.
GOJO is ok, just have to rub it on before getting your hands wet. Any of the orange/pumice stuff dries out my hands... and if I use it a couple times really lights up some tender spots... like between the fingers!
Old Nov 23, 2004 | 07:28 PM
stingr69's Avatar
stingr69
D&L hand cleaner works fine. I usualy wash with regular soap/water after that. It is real good at getting stuff out in the wash too.
-Mark.
Old Nov 23, 2004 | 07:55 PM
oregonsharkman's Avatar
oregonsharkman
gasoline
Old Nov 23, 2004 | 08:03 PM
C3 Stroker's Avatar
C3 Stroker
Fast Orange.
Definitely , Fast Orange!
Old Nov 23, 2004 | 08:26 PM
Jimydc's Avatar
Jimydc
1. First layer= WD-40
2. Second layer=Dishwashing liquid
What better things to cut grease and paint.
Jim C.
Old Nov 23, 2004 | 08:28 PM
i885744's Avatar
i885744
laquer thinner or castrol super clean waterless towelless hand cleaner.
Old Nov 23, 2004 | 08:32 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
fast orange.
you guys using solvents on your skin better be carefull.
Old Nov 24, 2004 | 04:05 PM
terry82's Avatar
terry82
lotus 76 i sent for the hand scrub .thanks guys
Old Nov 24, 2004 | 06:09 PM
ZD75blue's Avatar
ZD75blue
Originally Posted by turtlevette
fast orange.
Yeah...
It just says, "Avoid extended contact"
Spray it on, scrub, hose it off...
To hand cleaner
Old Nov 24, 2004 | 06:23 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Totally agree with the above, though TT gets honorable mention.
Old Nov 24, 2004 | 06:33 PM
Lotus76's Avatar
Lotus76
Let me know how you like it. remember to use some water and keep rubbing. you will be amazed. its great stuff
Old Nov 24, 2004 | 08:11 PM
Motor City Vette's Avatar
Motor City Vette
Fast Orange.
