Space Saver Spare
Old Nov 23, 2004 | 08:50 PM
greyghost79's Avatar
greyghost79
Default Space Saver Spare
anyone got a source for space saver spare tire (complete tire and wheel) for late 70's vettes. can't locate one in any of my catalogs or on the internet. any info appreciated
Old Nov 23, 2004 | 09:04 PM
ZD75blue's Avatar
ZD75blue
Didnt know you could run a space saver on the rear... Heard they burn out the posi...
I'm going to run a full size. Rather just rotate between 5 tires, instead of have a light weight, that requires pulling a front tire, putting it on the rear... and putting the donut on the front!
Old Nov 23, 2004 | 09:08 PM
greyghost79
that's what i'm doing now. just trying to save some weight..... and space. my tires are bigger than stock and it's a t-i-g-h-t fit to get it in the wheel well and hook it up.
Old Nov 23, 2004 | 09:15 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the space saver had to be the right size.... i have a space saver from a later 70s vette it is the same diameter/circumference so there is no issue with the posi....i got it from e-bay auction for $40 plus shipping, i also checked before i bought it to see if i could put a new tire on it and i can 195/80 15. you do however have to crank the spare carrier all the way up
Old Nov 23, 2004 | 09:18 PM
greyghost79
yeah, and i'm running 245/60's on my 79. so you can imagine how hard it is to get the wheel cranked up.
Old Nov 23, 2004 | 09:21 PM
markdtn's Avatar
markdtn
Try a space-saver from a late 80s IROC Camaro or Trans-Am. Should be a similar diameter to stock. You can also use a C4 space-saver, that's what I have.
Old Nov 23, 2004 | 09:22 PM
bobs77vet's Avatar
bobs77vet
i watched a sale at ebay and the guy kept dropping his price after each listing and when it was with 10 dollars of what i wanted to spend i e-mailed after the auction ended and made an offer....i wanted to save some weight and did not have a spare..
Old Nov 23, 2004 | 09:23 PM
greyghost79
i assume the c4 space saver is only available from GM??? if so, i guess they sell a $100 tire for about $500??? zat about right?
Old Nov 23, 2004 | 09:34 PM
markdtn's Avatar
markdtn
No, look at Corvette shows and Corvette Salvage yards. I paid $50 for mine and it was mint. Where are you located?
Old Nov 23, 2004 | 09:36 PM
greyghost79
near san antonio texas
bobs77vet's Avatar
bobs77vet
i doubt the c4 spare would work because of the different off sets
Old Nov 23, 2004 | 10:34 PM
markdtn's Avatar
markdtn
Fits fine. It is narrow enough that the offset makes little difference.
Old Nov 23, 2004 | 10:37 PM
bobs77vet's Avatar
bobs77vet
cool didn't know that. is the circumference the same as the rest of your tires?
Old Nov 24, 2004 | 07:13 AM
69Myway's Avatar
69Myway
About the only thing I have left from a 1981 that I have been parting out is the spare tire assembly. I have the tire/rim upper and lower housing, and brackets to install.
The tire is dry rotted, but appears to hold air. I wouldn't drive on it more than 50 miles or so if I had to use it.
$40 plus shipping sounds fair to me if it does to you.
Let me know.
mcdonald_chris@bellsouth.net
Old Nov 24, 2004 | 08:08 AM
markdtn's Avatar
markdtn
Yes, I am using 16" IROC wheels (4 fronts) and C4 size tires, can't remember off the top of my head, 255/50/16 maybe?
Old Nov 24, 2004 | 11:36 AM
exdrag77's Avatar
exdrag77
If you want to save even more weight, consider AAA! You can ditch the spare & jack then only take them along if doing a long cruise.
Old Nov 24, 2004 | 06:58 PM
joe73vette's Avatar
joe73vette
Unless you always rotate your 5 tires, the spare doesn't have to be the same size as the others, just the same diameter - for example a 225/70R15 is the same overall diameter as a 255/60R15 and a 255/55R16, and fits fine in the carrier. Joe
To Space Saver Spare
