Best way to remove radiator
Old Nov 23, 2004 | 09:33 PM
hudman's Avatar
hudman
Default Best way to remove radiator
I have to replace my radiator.
What is the best way to remove the radiator from a '68 BB with no power options or AC?
Do I need to remove the hood?
Old Nov 23, 2004 | 09:39 PM
jeaux's Avatar
jeaux
I did on my 75.The shroud is a "B" the hardest part of it, seems like it should be 2 piece's. They told me to loosen the rad. support bracket mine has A/C so that doesn't seem like a opition as I don't want to move those A/C fittings that much
Old Nov 23, 2004 | 09:49 PM
corvetteatv7's Avatar
corvetteatv7
The shroud is the worst part, but with the fan gone and no a/c or nothin else there it shouldn't be too difficult. then the rad just slips right out. There is no reason to remove the hood for this unless you want to for some reason.
Old Nov 23, 2004 | 11:43 PM
78whtshark's Avatar
78whtshark
It takes two people and a lot of juggling and pulling to take the shroud out. Then with the shroud out the radiator is easy.
I left the hood on, but others say taking the hood off and moving the radiator supports makes the job even easier.
Old Nov 23, 2004 | 11:56 PM
Schmucker's Avatar
Schmucker
I didn't have any accessories in or a suspension when I removed my radiator. It was fairly easy. Just unbolt and lift out, then get the shroud out. The shroud took some finese` but it came out. It didn't go back in. I went electric. So much more room.
Old Nov 24, 2004 | 05:29 AM
Larry B.'s Avatar
Larry B.
There are a bunch of different shroud configurations. Some are easy, some are very difficult. Some are one piece, some are smaller or shorter with extensions,while others have been "bubba-ized" (cut in half) . Some shrouds are almost impossible to get out without loosening the radiator support at the top. It does make the job much easier with the hood off.
Old Nov 24, 2004 | 05:35 AM
foundvettelifeisgood's Avatar
Pull the hood, but mark the position of the hinges with masking tape first. It's a much easier job with the hood gone.
Old Nov 24, 2004 | 07:05 AM
nhlgopens's Avatar
nhlgopens
also makes for a lesser chance of damaging something else...
To Best way to remove radiator
