headlight bypass valve
Old Nov 26, 2004 | 10:09 PM
greyghost79's Avatar
greyghost79
Default headlight bypass valve
what's the purpose of the headlight bypass valve under the drivers side dash. all i can see it does is keep the headlight doors from operating. what's the point in that?
Old Nov 26, 2004 | 10:13 PM
79ls1's Avatar
79ls1
So that you can change the bulbs with the power off or just leave them up.
Old Nov 26, 2004 | 10:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The point of the over ride is so you can raise the headlights without turning the lights on. This so you can change bulbs or wash the headlights and bucket.
Old Nov 26, 2004 | 10:32 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
it comes in handy when the vac switch in the headlight switch lets go and no longer raises the headlights. This is the mode i have operated in for the past 8 years. Its a backup.
Old Nov 26, 2004 | 10:34 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
snow and ice can make it hard for the doors to pop open
Old Nov 26, 2004 | 10:54 PM
bertmeister's Avatar
bertmeister
Who the he$$ drives their C3 in snow and ice?
Old Nov 26, 2004 | 10:56 PM
bobs77vet's Avatar
bobs77vet
the NCRS guys do, i'm sure of it.....
Old Nov 26, 2004 | 11:03 PM
70 LS1's Avatar
70 LS1
The real purpose is to allow you to open the doors with the engine off. In an ideal world with no leaks, the vacuum canister will hold enough vacuum to raise the lights even with the engine off. I have never met anyone that can actually do this, though.
Old Nov 27, 2004 | 12:33 AM
markdtn's Avatar
markdtn
If it keeps your lights from coming up it is plumbed wrong.
Old Nov 27, 2004 | 04:39 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Mine can do this..nice to know...hehe
Old Nov 27, 2004 | 11:19 AM
Packy76's Avatar
Packy76
I use mine at night alot when I'm in and out of the car during the evening that way the lights are already up !
Old Nov 27, 2004 | 06:35 PM
Megawatt's Avatar
Megawatt
I believe the plumbing is such that it is fail safe. The head lights come up with a loss of vacuum. I got rid of my switch. The vacuum lines were in the way when I would go under the dash. If I want to raise the headlights without the lights on I just disconnect the right vacuum line and bleed off the vacuum. I have it marked so I can remember which to disconnect.
I was trying to tidy up the engine compartment. I ran a single large vacuum hose from the manifold over the brake vacuum assist, teed to the vacuum assist and then under the left fender where with the right fittings I was able to connect all of the other hoses.
To headlight bypass valve
