manual steering gearbox
Old Nov 28, 2004 | 08:45 AM
greyghost79's Avatar
greyghost79
Default manual steering gearbox
what type of lube is used in the manual steering gear box? is it oil or grease? when filling do you remove the "fill here" and "check here" screws at the same time? do you just fill until it runs out? thanks.
Old Nov 28, 2004 | 09:22 AM
redvetracr's Avatar
redvetracr
I,m sure GM sells/sold a specific grease for this application but i use synthetic chassis grease in mine.....grease NOT gear lube...
...redvetracr
Old Nov 28, 2004 | 11:48 AM
GTR1999's Avatar
GTR1999
...redvetracr
Use Mobil 1 red auto grease. An empty box will use about 11 oz. You don't want to overfill it because the grease will expand under heat. It may be tought to accurately fill the box through the cover screws although that is the way the books say to do it. You can't remove the cover either unless you know how to adjust the box. If the box has never been lubed, then you may find it is 1/2 full with overheated muck. I usually have guy remove the box then clean and set it up after installing new grease,it takes more work to do this but you'll know it's done right. It's a nice Winter weekend job while the car is in the garage.
Gary
Old Nov 28, 2004 | 02:58 PM
75 Hot One's Avatar
75 Hot One
The special GM grease has been discontinued and its replacement has been discontinued. I use Pennzoil red 707 grease (I think that's the right #) based on a clinic at Bloomington and haven't had any problems.
To top up, best to remove top cover so you can see what you're doing & to avoid overfill- must leave some room for gear to move, then you have to adjust play.
Old Nov 28, 2004 | 05:23 PM
greyghost79
if i remove the top cover will i have to adjust lash when i re-install it???
Old Nov 28, 2004 | 06:41 PM
GTR1999's Avatar
GTR1999
Yes, the screw through the top of the cover will have to be moved-this is the lash adjusting screw. It is much harder to adjust the lash in the car, that's not to say it can't be done. If you don't want to go through this try adding through the screws while rotating the steering from lock to lock. Have the front end off the ground. You might be aboe to work more grease in that way.
Gary
Old Nov 28, 2004 | 07:26 PM
3X2's Avatar
3X2
I'm going from memory here. I "think" one of the cover bolt holes is not a blind hole. I got a bolt thats the same size as the cover bolt, drilled and tapped it for a grease fitting and injected the grease using a grease gun. It was about 15 years ago, so the memory is.........well......... vague!
Mark
Old Nov 28, 2004 | 08:28 PM
chuck d's Avatar
chuck d
Default Grease in steering box.
Drilling out a spare cover bolt and installing a zerk fitting works great.
chuck d
Old Nov 29, 2004 | 01:14 AM
C8H18's Avatar
C8H18
GM #12377985 (chassis grease) is not discontinued. That's what they now designate for the box. It superceded the orig grease. Other quality chassis greases should work equally well or better - they should have a high drop point and be resistant to heat because of the proximity to the exhaust.
To manual steering gearbox
