Factory Side exhaust with headers [PICS]
Old Nov 29, 2004 | 07:56 AM
LFZ's Avatar
LFZ
Default Factory Side exhaust with headers [PICS]
I know there are some guys on here that want to run side exit headers under factory exhaust covers. I thought i would share some pics of my setup.
Hedman Side Exhaust headers...wrappings suck.
This is the whole setup...I cut off the front pipe of the Allens mufflers and welded my own bent setup...Fit is great, but they hang down from below the covers..but it doesn't look bad.
I will be gutting the mufflers and having the whole system JetHot coated.
Old Nov 29, 2004 | 09:16 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Nice looking work. Are you planning on coating the headers too? If so I would think you could do away with the heat wrapping. Either way, make sure to post follow up pics.
Old Nov 29, 2004 | 09:23 AM
79-L-82's Avatar
79-L-82
Where do you get those?
All I ever see it the Hookers.
How much was the setup?
Old Nov 29, 2004 | 09:53 AM
LFZ's Avatar
LFZ
Eddie...the wrapping is definitely going away..i only did it because i tried to coat the headers myself with POR-20 and it all flaked off. So i sprayed it with VHT and wrapped them to get me through the summer. Jet-hot on the headers and sidepipes..only way to go.
Old Nov 29, 2004 | 09:55 AM
LFZ's Avatar
LFZ
I got the headers from summit, and the sidepipes came from Allens Exhaust. The headers were about $120 not coated, and the mufflers, if i remember..were almost $800 from allens.
I've actually thought about just welding in a Stainlessworks chambered muffler in the place of the muffler now, but the way the tips and everything are offset, it looks alittle tricky..might figure something out if i don't like the sound of these gutted mufflers.
Old Nov 29, 2004 | 02:22 PM
VettePower's Avatar
VettePower
I have a set of Allen's sidepipes on my Vette, and believe me, you don't need to gut them. They are deafening as they are!!!!
Old Nov 29, 2004 | 04:22 PM
Schmucker's Avatar
Schmucker
About how much are those headers and where did you get them? I am having a hard time finding them on the typical performance parts web sites.
Old Nov 29, 2004 | 05:36 PM
CrossedFlags77's Avatar
CrossedFlags77
I got my Hedman sidepipe headers from Summit. I searched there website a week ago looking for them for another person but I couldnt find them, so I would probably give them a call and see if they still carry them.
Old Nov 29, 2004 | 06:01 PM
NHvette's Avatar
NHvette
I used to see them in summit online ... weren't there last time.
Price is right -- ~120 sounds correct.
Old Nov 29, 2004 | 06:59 PM
71vetteLT-1's Avatar
71vetteLT-1
Headers on Summit
those are the headers on summit...135 bucks, the picture isn't wrong...if you want you can go to the Hedman website and look at product images, the part number is 68280
Old Nov 30, 2004 | 12:57 AM
Schmucker's Avatar
Schmucker
Okay, thanks. I'll have to pick a pair of those up as I'm going to custom make my own sidepipes out of 3" stainless. How is the fitment? I'm especially curious of the header outlet position.
Old Nov 30, 2004 | 07:45 AM
LFZ's Avatar
LFZ
fit is fine..no problems. I was wanting to make my own pipes too...what are you going to use as mufflers?
Old Nov 30, 2004 | 12:15 PM
71vetteLT-1
when we do ours (will be a whilllleee since we are usin the stock sidepipes until we have the money) we are most likely gonna get those hedmans and some 3 inch mandrel bent pieces and weld an elbow to a straight 3 inch stainless pipe and use the spiral turbo baffles which are just inserts you put inside the pipe...
Old Nov 30, 2004 | 03:21 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Very nice!
Old Nov 30, 2004 | 04:48 PM
Schmucker's Avatar
Schmucker
Yep that's basically my plan except I was going to use 2-3 in each tube of the the 11" long auger style mufflers Speedway sells for like $15. Seems like a much cheaper and easier alternative.
To Factory Side exhaust with headers [PICS]
