Reargear oil..
Old Nov 29, 2004 | 11:19 AM
BB wowbagger's Avatar
BB wowbagger
Default Reargear oil..
Theres an ongoing discussion between my friends on which oil is the best for the rearaxel.
Some state that 80-140 is the way to go because of its thickness and it will help dampen the load on the gears.
The other half claims that its unnecessary to go that thick and 80-90 oil is just plenty enough to lube and dampen the gearload.
Many of the "rearaxel pro`s/rebuilders" says that 80-140 is the oil to use.
Whats your take on this issue?
Old Nov 29, 2004 | 11:22 AM
pws69's Avatar
pws69
Mobil 1 + GM Posi Additive and be done with it!
Old Nov 29, 2004 | 11:39 AM
stingraymaniac's Avatar
stingraymaniac
Thats something i want to know also
Old Nov 29, 2004 | 03:33 PM
71coupe's Avatar
71coupe
Standard GL-5 with GM Posi additive. No problems.
Old Nov 29, 2004 | 04:50 PM
GTR1999's Avatar
GTR1999
I use the 80-90 gear oil with 2 bottles of the GM additive.
Gary
Old Nov 29, 2004 | 05:04 PM
A C's Avatar
A C
Cruise-In II Veteran
I used 80w-90, but on the container Valvoline said posi additive wasn't necessary...do they add that right in the lube now? I have only had mine in and out of the garage since the rear end rebuild...not even around the block yet.
Old Nov 29, 2004 | 05:07 PM
GTR1999's Avatar
GTR1999
AC, I used Valvoline in the past and didn't use the GM additive, it freakin knocked all the time. Get the 2 bottles for $14 and save yourself a headache.
Gary
Old Nov 29, 2004 | 05:49 PM
A C's Avatar
A C
Gary
Oh great! It was messy the first time! I can imagine after I add the stuff past the bottom of the fill hole!
Thanks for the advice.
Old Nov 29, 2004 | 08:10 PM
Megawatt's Avatar
Megawatt
I use Mobile 1 but no GM additive and no posi problems.
Old Nov 29, 2004 | 08:24 PM
Twin_Turbo's Avatar
Twin_Turbo
I use kroon oil (dutch brand) 80W140 GL5 full synthetic.
Old Nov 29, 2004 | 09:41 PM
StylemasterZ's Avatar
StylemasterZ
I had used 80w-90 and some off brand posi additive. Talk about bumps in the night. And the day, afternoon, evenings....
Replaced it with Valvoline 80w-90 and one bottle of the GM additive and nary a noise.
I looked at the 80W-140 oil, but the "directions" stated it was to be used in a posi for "top off only."
Old Nov 29, 2004 | 10:04 PM
Lotus76's Avatar
Lotus76
I use Kendall Special Limited Slip Axle Gear Lube 80-90W
With a 4oz bottle GM Limited Slip Axle Lubricant Additive P/N 1052358
Works Great no noise, No Problems
Old Nov 30, 2004 | 07:31 PM
ewalker302's Avatar
ewalker302
I used the Valvoline semi synthetic only, and I have had no problems at all.
Old Dec 1, 2004 | 02:01 AM
Larsson's Avatar
Larsson
BB wowbagger
Please post here when you decided what oil to use, I'm about to do this change this winter too.
I have a whining sound from the rear axle when I let of gas at some speeds, i figured that the first thing to change is the oil.
To Reargear oil..
