Headlights
Old Nov 30, 2004 | 12:13 PM
76mike's Avatar
76mike
Default Headlights
Headlights. Mine won't go down. Something about vacuum hoses??? I don't know looks like some tubes are just not connected. Any help? anyone seen this before?
Old Nov 30, 2004 | 12:32 PM
markdtn's Avatar
markdtn
Get a vacuum diagram from any of the catalogs and figure what is disconnected. There are relay valves near the actuators that work together with a vacuum signal to make the lights go up and down.
Old Nov 30, 2004 | 01:25 PM
72GACRZR's Avatar
72GACRZR
Fail safe mode is up, so you have a leak. Get the above mentioned diagram and start checking components. A search on here will bring numerous past threads, and here's a site to help you get started.
http://vetteworks.tripod.com/techdocuments/Vaccum.html
and here's another
http://www.corvette-101.com/
Good luck.
Old Nov 30, 2004 | 01:38 PM
wcsinx's Avatar
wcsinx
Yeah there might be a few members here who have seen this one.
The above guides are good ones. You can PM me if you'd like. I rebuilt mine from the ground up. The vacuum system is really quite simple.
To Headlights
