Frame Rust: What's the Big Deal?
Old Nov 30, 2004 | 05:40 PM
Boston!'s Avatar
Boston!
Default Frame Rust: What's the Big Deal?
After reading all the warnings about frame and birdcage rust, I did crawl around under my 72 before I bought it, and checked body gaps, and I think I'm okay. (It would have been hard to turn around and drive home 1000 miles if I'd decided otherwise, I'll admit- didn't realize how friendly and willing forum members are to check stuff out at the time...) The question I can't seem to find a simple answer to browsing other threads is, "What's the big deal?" What happens if your frame has rust- will the car fall apart, or will handling be poor, or what?
-Owner of a former NY car
-=Boston!=-
Old Nov 30, 2004 | 05:42 PM
GTR1999's Avatar
GTR1999
Extreme cases the frame will collapse and crack the body. The doors won't open. Windshield and glass tops will crack.
Old Nov 30, 2004 | 05:45 PM
matchframe's Avatar
matchframe
The frame is the backbone of the Vette. If it loses it's strength, the fiberglass alone will not hold the car together. Suspension parts could break away, like the front A-Arms and could become very dangerous.
wcsinx's Avatar
wcsinx
seen it happen, and it ain't pretty nor cheap
Less extreme cases can cause doors to bind when jacking one corner. Some guys will tell you this is normal, but I can jack any corner of my '76, and the doors don't twitch a millimeter. In fact, I think this might be a quick and easy test for frame integrity. ...jack up a corner, if either door binds, walk away
Old Nov 30, 2004 | 05:52 PM
Paul L's Avatar
Paul L
You may hurt/kill yourself and/or others.
Old Nov 30, 2004 | 05:53 PM
NHvette's Avatar
NHvette
**** Ah Paul, You beat me to it with your picture. ****
Yes - all of the above if left unchecked.
Here is an example of rust that weakened the frame in an already weak area:
http://temp.corvetteforum.net/c3/paul79//rust.jpg
This is the same picture above.
Old Nov 30, 2004 | 05:57 PM
Paul L's Avatar
Paul L
That was initiated by a parking lot bump. Think of that one on the highway.
Old Nov 30, 2004 | 05:59 PM
Wrencher's Avatar
Wrencher
Look at a picture of the frame (in the manual or AIM). The critical area is the "kickups" that are welded to the frame rails and have the trailing arms bolted on to the back. It's a natural "pocket" that holds moisture, salt, dirt, etc... and that's the area that falls apart. Looking at the picture, it becomes clear that you could loose the trailing arm or rear part of the frame if it was full of cancer...
Hans
Old Nov 30, 2004 | 06:30 PM
Paul L's Avatar
Paul L
Be careful when you buy these cars.
Old Nov 30, 2004 | 06:57 PM
stpman's Avatar
stpman
Here's another horror picture for you
Steve
Old Nov 30, 2004 | 07:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It's true it is very dangerous, have been pondering this for some time, people buy these cars because the body usuallly looks great and never even take close look at points that can rust.
They jump in and go for a ride up to highway speeds on the way home after buying the car without ever even knowing if the car is structurally safe. I encourage everyone to take a close look at thier frame and look even closer before putting the 500HP crate motor in
Old Nov 30, 2004 | 07:20 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Rust is to Corvettes like Cancer is to the human body.
Old Nov 30, 2004 | 07:26 PM
MikeC's Avatar
MikeC
I'm in the progress of repairing frame and birdcage rust and when I got down to where I couuld see the damage, I just about crapped myself.... if I had of been in any kind of accident I would not have been protected.... the birdcage would have collapsed.... my frame was bad but not as bad as the birdcage was.
Old Nov 30, 2004 | 07:49 PM
carl a's Avatar
carl a
its the whole design of the windshield frame posts- made to channel water under the trim down the post to the wiper well and down to the ground. like a gutter...i sealed the trim with the caulk they use to hold the windshiel in place so the water goes up and over------poor design on g.m's part
Old Nov 30, 2004 | 07:58 PM
Z-man's Avatar
Z-man
AAAGGGHHHHH!!!! My eyes, my eyes!!! Stop it with the rust photos!
Old Nov 30, 2004 | 08:06 PM
Paul L's Avatar
Paul L
These cars can be pretty until you look underneath. Buyer beware!
Old Nov 30, 2004 | 08:54 PM
dfseidel's Avatar
dfseidel
The frame and the body mounts are pretty "easy" to check -- what is the best way to check the birdcage around the windshield and other problem areas??
To Frame Rust: What's the Big Deal?
Old Nov 30, 2004 | 09:01 PM
Cali,68,L-79's Avatar
Cali,68,L-79
True with the exceptions of convertibles. Mine has zero rust, never has never will but try opening the door with one jack stand up.
Old Nov 30, 2004 | 09:08 PM
greyghost79's Avatar
greyghost79
i've never seen a 25+ year old car that didn't have some rust on the frame. how can you tell if its surface rust or something more serious? what's the best way to remove surface rust on a frame?
Old Nov 30, 2004 | 09:23 PM
lostpatrolman's Avatar
lostpatrolman
If it is surface rust, you can wire wheel it off and get bare metal, then just paint over it. In some of the bad areas, you can most likely stab a screw driver through the frame.
