Stroker Kit
Old Dec 1, 2004 | 08:54 AM
DeanW's Avatar
DeanW
Default Stroker Kit
Has anyone ever delt with this buisness??
http://www.larrysperformance.com/data/assemkits.html
They sell a 383 stroker kit for $1200.00. They say the crank is cast steel and I can spec the cam.
This seems cheap to me.
Any comments?
Old Dec 1, 2004 | 09:15 AM
comp's Avatar
comp
no link ......
Old Dec 1, 2004 | 09:22 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
TRACK PRO BLOCKS & ASSEMBLY KITS
EngineFully prepared block, magged, powerhoned, brass freeze plugs, cam bearings, pistons, reconditioned crank & rods, MI 77 bearings, moly rings, performance cam and lifters, FelPro gaskets, high volume oil pump, double roller chain, all parts balanced.
CHEVY CAST PISTONS FORGED
350 2 Bolt $745.00 $845.00
350 4 Bolt $845.00 $945.00
383 2 Bolt $995.00 $1099.00
383 4 Bolt $1100.00 $1200.00
391 2 Bolt $1145.00 $1245.00
391 4 Bolt $1245.00 $1345.00
415 2 Bolt $1345.00 $1445.00
415 4 Bolt $1445.00 $1545.00
TRACK PRO 4 Bolt Block only - $349.00
Also available fully assembled
LARRY'S CUSTOM SMALL BLOCK CHEVY RODS
STREET PRO RODS
STAGE 1-MAG, MOLY BOLTS (180,000 PSI), SIZE BIG END Set of 8 $125.00
STAGE 2-MAG, SHOT PEEN, MOLY BOLTS (180,000 PSI), SIZE BIG END Set of 8 $149.00
TRACK PRO RODS
STAGE 1-MAG, POLISH BEAMS, SHOT PEEN, MOLY BOLTS (180,000 PSI), SIZE BIG END Set of 8 $195.00
STAGE 2-MAG, HEAT TREATED, POLISH BEAMS, SHOT PEEN, MOLY BOLTS (180,000 PSI), SIZE BIG END Set of 8 $240.00
STAGE 3-MAG, HEAT TREATED, POLISH BEAMS, SHOT PEEN, MOLY BOLTS (180,000 PSI), SIZE BIG END, BUSH SMALL END Set of 8 $299.00
Taken from his webpage above.
Old Dec 1, 2004 | 09:24 AM
comp's Avatar
comp
didn't connect for me doesn't seem to bad
Old Dec 1, 2004 | 09:51 AM
mandm1200's Avatar
mandm1200
I won't say it is cheap, I think it about average in price. The crank, rods, block are reconditioned. Are you going to pick the cam of your choice or do they let you pick from a limited selection? It does sound like a fair deal.
I picked up a stroker kit from a local engine builder/machine shop for about $850. This was all new parts with balancing: Scat crank, Scat rods, Speed Pro pistons, moly rings, bearings, complete gasket kit plus add'l gaskets for vortec heads, SFI flex plate, harmonic damper. I picked up a prepped block from a friend for $350.
Old Dec 1, 2004 | 10:00 AM
DeanW's Avatar
DeanW
I asked them about the cam. They said I can pick the cam spec.
I am trying to decide between rebuilding my original motor (69 350/350)
or putting together a stroker. Money will dictate the final answer, but, I think with a kit like this one the cost will be about the same.
Any other suggestions will be greaty appreciated.
Thanks.
Old Dec 1, 2004 | 12:04 PM
gkull's Avatar
gkull
It said that they had a long rod 391 kit. I had one of these combos before. If you could get it in a long block & internally balanced they are better than a 383
To Stroker Kit
