exhaust hanger on trans
Old Dec 1, 2004 | 03:19 PM
hotrodrik's Avatar
hotrodrik
Default exhaust hanger on trans
I have a 77 vette that has duel exhaust on it, while rebuilding the rear suspension, I unbolted the pipes to get them out of the way,[they are in bad shape and are getting replaced ]. I noticed that the pass. side pipe was held on with the factory hanger support bolted on the trans, the drivers pipe was not attached to anything except the rear hanger at the rear bumper.Is there a factory hanger that will work, or one that I can modify to work so that both pipes can be secured. The car has a turbo 350 trans. I 've seen hangers for a turbo 400 but the mounting holes are different.Anyone have any ideas?
Old Dec 1, 2004 | 03:43 PM
stpman's Avatar
stpman
On a 77 there would have only been a pipe on the pass side from the cat con back
Steve
Old Dec 1, 2004 | 03:45 PM
djcwardog's Avatar
djcwardog
I think you can buy the two-pipe hanger (for earlier C-3's like my 1973) from CC or any vendor. It replaces the one you have and lets you run dual pipes properly secured.
To exhaust hanger on trans
