Not having enough power is actually a concern my brother has as well about doing this.
I'm either driving in town or doing 70+ mph on the freeway. So I'm hoping it's not a problem, but......
What kind of power do you think it will take? Sounds like a good excuse to build an engine .
I'm getting the transmission for free BTW.
Don't worry about not having enough power to pull OD. It's all about torque, and a mildly cammed 350 has plenty at 2000 to cruise comfortably, and even accelerate for gentle passes. A high hp motor lacks low end torque, so they can't run tall gears with OD. Joe
PS, if you run a vacuum switch in the power lead, it will unlock the converter for passing, giving a little more RPM and power when you need it without downshifting.
