I keep blowing a A/C fuse
Old Dec 2, 2004 | 02:43 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Default I keep blowing a A/C fuse
I replaced the blower motor last nite because my original
was noisey. With the key in the on position, it works fine
and is quiet. when I switch on the ac, I keep blowing fuses
I checked all the wiring from the console to harness under the
hood, none frayed for crispy burnt, could this be a relay? what
are the first steps to pulling bugs out of this.
Old Dec 2, 2004 | 05:24 PM
MEGALADON's Avatar
MEGALADON
I know this is a hard question to determine with out being
there, but at least get me in the rite direction
on how to start
Old Dec 2, 2004 | 05:31 PM
1970-Bronze's Avatar
1970-Bronze
Silly question, but are you using the correct fuse size?
You may also want to check the switch to see if it's shorting to groung when you switch on the AC.
Old Dec 2, 2004 | 05:36 PM
MEGALADON's Avatar
MEGALADON
Its a 25 amp fuse. not sure how to check the switch.
The high low switch or the a/c switch.
When I get off work here at 7, Im gonna put
the old blower back on and see if it still blows
the fuse.
To I keep blowing a A/C fuse
