Brake bleeding
Old Dec 4, 2004 | 12:22 PM
jeaux's Avatar
jeaux
Default Brake bleeding
While doing my rebiuld of my front end after tussling with the coil spring I noticed I forgot to move the caliper back to the front so I had to disconnect the brake line now I guess I have to bleed the whole system or do I what is the proper way any tips . Thanks in Advance
Old Dec 4, 2004 | 12:32 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Not really that bad. The only thing you have to worry about is the bleeders. You might want to hit them with PB blaster or WD-40 a day or so ahead of time to make sure that they come loose. If you're only disconnecting the calipers at the front, i don't think that you have to bleed the backs.
Old Dec 4, 2004 | 01:09 PM
carl a's Avatar
carl a
put some anti size on those puppies once you get em loose
Old Dec 5, 2004 | 05:03 AM
jeaux's Avatar
jeaux
So you think I can get away with just the front huh
Old Dec 5, 2004 | 05:42 AM
gotchashawn's Avatar
gotchashawn
The book says the bleeding sequence is :
left rear inner, left rear outer, right rear inner, right rear outer, then left front , then right front.
Old Dec 5, 2004 | 09:55 AM
75 Hot One's Avatar
75 Hot One
The front and rear systems are separate- that's why there are two reservoirs in the master cylinder. You should need to bleed only the front system.
Old Dec 5, 2004 | 11:23 AM
73jst4fun's Avatar
73jst4fun
However, if you haven't bled your brakes in awhile (dirty fluid in the master cylinder) now would be a good time to do it and it's not a big deal, you just need someone to pump the brakes for you... I just got done doing my entire brake system...
To Brake bleeding
