getting through the winter?
Old Dec 5, 2004 | 11:37 AM
killain's Avatar
killain
Oldtimer
Default getting through the winter?
How many of you disconnect your battery during the winter and just leave the car sit, or do you start it once in a while?
Old Dec 5, 2004 | 12:01 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Why take a chance ? Just disconnect it....
Or get the 'kill switch' for $10
Old Dec 5, 2004 | 12:03 PM
CGGorman's Avatar
CGGorman
I use a battery maintainer.
Old Dec 5, 2004 | 12:24 PM
'77BABE's Avatar
'77BABE
On top of that I start it once in a while, for the car (and for myself)
Old Dec 5, 2004 | 01:32 PM
robertmc48's Avatar
robertmc48
Veteran: Marine Corps
I use gasoline stabilizer....battery disconnect switch...battery tender. I have been told it's not a good idea to start a car during the winter unless you can run it long enough to get it to full operating tempature to "burn off" moisture. I also "fog" the engine at shutdown with a 1:5 mixture of Marvel Mystery Oil and gasoline. I use the same mixture to start up up again in the spring, by pouring it into the carburetor. I learned that from an old timer who wrote a article in Old Cars/ I called him up and he swore by it.
Old Dec 5, 2004 | 01:45 PM
Mike Ward's Avatar
Mike Ward
You may be doing it to make yourself happy, but you're not doing the car any favours. Cold starts are the hardest on an engine.
The old myth about seals drying out is
Let it sleep in piece.
Old Dec 5, 2004 | 01:46 PM
Stoge's Avatar
Stoge
I usually just drive mine once or twice a month. They can be driven *gasp* in snow.
Old Dec 5, 2004 | 05:30 PM
BerniesVette's Avatar
BerniesVette
I used Marvel Mystery Oil as part of the winterizing process for my houseboat. All the boat owners at the marina did it. Just pour it thru the carb until it was smoking really good and shut it off until Spring. It coated the internals and kept them from rusting. I am lucky now because I do get to drive at least on weekends here in Knoxville. I installed a kill switch too. And I use it anytime I have the car parked for any length of time. Don't have to but I have become **** about some things, being a pilot and a boat owner one learns that safety is important. I also burnt a TR-6 to the ground doing something I knew I shouldn't. Some lessons are learned the hard way and experience is a strict teacher!
Old Dec 5, 2004 | 08:37 PM
stingr69's Avatar
stingr69
I like the trickle charger with a Christmas light timer hooked up to it. Seems like it would be good for the battery and it will prevent damage to the factory clock. Seasonal disconnecting of the battery can cause it to fail.
-Mark.
Old Dec 5, 2004 | 11:42 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I use my cut-off switch each time I park.
Old Dec 5, 2004 | 11:45 PM
lostpatrolman's Avatar
lostpatrolman
winter, whats that?
Old Dec 5, 2004 | 11:53 PM
CGGorman's Avatar
CGGorman
I can't disagree about leaving it rest for the winter, but I MUST disagree about shrinking seals. I had the "honor" of rebuilding the carburetors on a '69 Dodge p/u and a 50's 8N Ford tractor this summer. Neither of them had been started in two decades. Neither of them had had any storage prep done on them. Both were stored in a garage. When I filled the truck with gas and started cranking it, the carb was LITERALLY pouring fuel onto the intake. Same way with the 8N. Before I even got the carbs apart I could see the gaps in the gaskets. They had shrunk to point that they were actually INSIDE the carbs in several places. Hard as a rock and total waste. Needless to say, they were also varnished very badly. Some passages were actually blocked.
I don't think could happen in the course of a winter, but it CAN happen.
Old Dec 6, 2004 | 01:48 AM
carl a's Avatar
carl a
battery blade type disconnect is always open unless i want to go ,then i close it-no electrical shorts when im not around,,,seen a neighborhood service center burn and melt steel beams 3 yrs ago because of a electric short in a customers van at 4 am,,start her up and let her run till temp hits 198- my harley sits all year and all i do is turn her over and start her once a year,,, change the oil, and plugs once in a while--16,000 org miles on a 79 -never ride anymore and the bike just fine,, think i drove it 10 miles in 4 or 5 yrs
Old Dec 6, 2004 | 05:08 AM
Larry B.'s Avatar
Larry B.
I drive mine execpt I don't need to run the A/C as often
Old Dec 6, 2004 | 07:28 AM
vetteonr's Avatar
vetteonr
This is the first year I'm using battery maintainer with the battery in the car. I used to just take the battery out and store it in the house. In the springtime she'd fire right up. This seems a lot easier. We'll see.
Old Dec 6, 2004 | 08:13 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
i go out every week and start it and roll it forward a few feet and let it idle and come up to temp... that way the stuff gets lubed and condensation gets cooked out as well...kinda eliminates the need to disconnect IMHO
Old Dec 6, 2004 | 08:29 AM
comp's Avatar
comp
good idea for all
To getting through the winter?
Old Dec 6, 2004 | 08:58 AM
exdrag77's Avatar
exdrag77
I built a big rotissary that I use to flip the car every once in a while. That way gravity doesn't pull in one direction all the time!
Seriously though, I've never used stabilizer since I've never found bad fuel after sitting even for several years. The mystery oil suggestion above sounds like a good idea next time I'm going to park one for a long spell. I do disconnect battery while parked so no electrical problems arise. Once I took my 66 Chevelle out of storage to put on a polished alternator then put it back away. In the spring when I went to get it out, turns out the pos wire ended up on the exhaust and melted through. Burned out every wire under the hood! Lucky that's all the damage that I found. Very easily could have burned grandmas house down!!!
I also use Optima sealed batteries now in all my vehicles. I drained a 5 year old optima dead a while back (dome light left on) and it sat for 4 months that way. Charged it up and I use it still in the 77 with no problems!!
I wish I was back in Key West so I didn't have to park either for so long!
Old Dec 6, 2004 | 09:28 AM
nhlgopens's Avatar
nhlgopens
Start him up about every 3 or 4 weeks and let run for about 20 minutes. Wife can't stand it... chambered pipes rattle the whole house.
Old Dec 6, 2004 | 09:34 AM
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
Mines on garage dollies (so I can move it around), covered, and with a blade type battery disconnect. The garage is heated, so I don't think it's nessesary to start it once in a while.
