Servicing the C3 Differential
Old Dec 5, 2004 | 07:20 PM
Ex_F-Body_Enthusiast's Avatar
Default Servicing the C3 Differential
So, yesterday I was under my '82 finishing up installing new rear SS brake calipers and SS lines along with new Bilstein Sports, and I casually started to think about one of my next tasks, which is changing out the gear oil in the differential. I crawled under the pumpkin area looking for the drainplug thinking it would be just like my C5. No drain plug to be found!
I'm pretty lazy, so there's no friggin' way I'm pulling down the entire rear suspension to remove the inspection cover, I'll buy/borrow one of those vacuum purge units before that; but I'm just wondering what other C3 owners do when its time to change the differential fluid?? There has to be an easier way!
Old Dec 5, 2004 | 07:23 PM
Twin_Turbo's Avatar
Twin_Turbo
Nope, cracking open the coconut is the only way. Thanks to GM, they must have saved millions by skimping on a 0.01$ drain plug
Old Dec 5, 2004 | 08:10 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I suck out the oil with one of those things that looks like a oversized hypodermic needle available at your local auto store. Also use it to refill. In this month's issue of Corvette Fever is an article on drilling and tapping for a diff drain plug if your're interested. Appears the kit comes with a template to locate where to drill.
Old Dec 5, 2004 | 08:14 PM
Twin_Turbo's Avatar
Twin_Turbo
Do not drill & tap the 80-82 alu diff for a drain plug unless you want to wreck it. The casting will not hold up to the plug being torqued. The only way to properly do it is to install a threaded insert.
Old Dec 5, 2004 | 08:35 PM
Thanks guys for the replies! I'll stop by my favorite Auto Zone and see if I can buy one of those suction pumps and drain the fluid through the fill hole. I'm looking forward to that mess!!
Old Dec 5, 2004 | 09:10 PM
Cali,68,L-79's Avatar
Cali,68,L-79
No big deal. I have a brake bleeder pump for $15 from Autozone which I use for brakes, sucking out differential/ tranny fluid etc. etc. Easy to do no mess just about 20 minutes from start to finish.
To Servicing the C3 Differential
