Norval, I have a question regarding....
Can you give me any tips?
As always, Thank you!!!
The other carb looked like someone bunched in the floats, I assume automation crunched them, both front and back. Of the 3 new carbs I bought the one with the internal leak was the best.
Anyway for the blower you want the carb power valves indexed off the intake manifold, not the one on top of the blower but the intake.
To do this you can either buy special ones from holley that like mine use a special tube from the intake directly to the power valve of using devcon alumim remove the existing blow check valve, fill in part of this area and redrill for a reference tube.
When I started doing each carb I dismantled them , using a flat glass plate made sure all surfaces were flat, the gaskets needed to be scrapped off and all new gaskets bought.
Anyway I immediately drill the butterflies, all 8 throttles for bypass, installed .015 wires in the idle circuit, drilled and taped the transfer slots for screw in jets, left jetting alone, removed the springs from the power valves completely, vacuum holds them closed, boost blows them open,
Lean out the carb using the idle circuit, not jetting.
Hook up reference tubes to the intake.
I run 15-1 cruising down the highway, plugs are white but the minute the boost crosses from vacuum the power valves open giving you 13-1 under any boost.
I run 43 degrees advance, use electronics to bring it in, use a timing computer to pull timing out under boost.
I get 15 mpg driveing 1/2 and 1/2, car never ever fouls plugs, runs cool enough that most of the time I run no fan, easy starting and shuts down clean.
Holley really makes it easy with their new blower carbs.
While I find alot of problems with holley, particularly too rich at idle once reworked they give me no problem
You need the power valve, don't try to get along without them ever, no way except all out drag, never on the street,
You need them reference to the blower boost, not the vacuum under the carb, you will have fantastic vacuum under the carb, 18-20 inches.
I run lots of boost, 12 pounds, 15% overdrive for real bottom end grunt.
It makes for really nice around town pull, sure if you run alot of wide open runs you would be pushing it but with 15% around town pulling away from lights I often see 10 pounds without pushing it.
Alot of my mods I don't really know until I tear the carb down then I start fixing what I feel needs changing. I will redrill, tap and thead in jetting, I do like the .015 wires in the idle circuit and I still like the holes in the throttle plates.
Pulleys? I made a special pulley for the blower. It has the accessory belts in front, not behind the blower belt. This allows the alternator and power steering pump to be mount infront of the heads, one on each side, down low.
Using the stock setup with the accessories behind the blower belt forces you to mount the accessories high or off to the sides to clear the motor.
I like my setup alot better.
I think I have a spare blower pulley with the accessory pulley in front down in the shop?????
But what is really happeining, the motor is seeing 5 pounds of boost and needs the extra fuel.
I block off the existing power valve reference points which is under the carb with devcon alumimun and drill a new hole with hoses that connect to the intake under the motor. Now the carb sees what is happening at the motor, not under the carbs so when add fuel is needed the power valves open regardless of what the intake on top of the blower is telling it.
Remember as you build boost in the intake on the motor the vacuum under the carbs is really good and the power valves are totally confused if they are seeing the vacuum under the carbs.
Hope this helps.
I actually run 14.5 compression with a boost/retart and 94 octane fuel.
GENE
With fuel injection I have to start learning all over again.
Something about not being able to teach an old dog new tricks???
I can work through any carb problem. I actually have a carb carefully cut up for referenceing every passage and if I have a problem I just take out the carb and work through why the problem exists and do something about it.
I feel my carbs are well dialed in, give me about 15 mpg and don't load up ever.
Maybe someday Gene but not now.
