Engine overheats while going uphill...?
Old Dec 6, 2004 | 12:37 PM
humiliategravity's Avatar
humiliategravity
Default Engine overheats while going uphill...?
I'm not sure what to make of this... twice yesterday on the highway my engine overheated while going up moderately steep hills. The gauge started climbing until it reached red over the course of 20-30 seconds, so I coasted off and let it cool down.
I'm pretty sure the overheating was not related to engine load. The second time, I kept a reasonable rpm in a third gear so I only had to use part throttle. On the flats I can use a higher throttle for a longer time and not have it overheat. It seems to be all or nothing, too - it's at either 200 deg on flat ground or 250 uphill.
I have my temp sensor mounted in the intake manifold, adjacent to the water inlet. Could it be that the water sloshes back and it doesn't get an accurate reading while going uphill? I haven't had the new engine too long so I'm still working out its bugs.
Any suggestions? Thanks everyone.
Dave
Old Dec 6, 2004 | 12:44 PM
76custompaint's Avatar
76custompaint
What is your engine and radiator set up?
Old Dec 6, 2004 | 12:45 PM
NHvette's Avatar
NHvette
I'm sure you've checked, but it sounds like low coolant level.
When the engine tilts back, the water pump sucks air.
Well, I guess it could be the sensor up top. Maybe try unscrewing the sensor and 'burping' any air from that area ?
Old Dec 6, 2004 | 12:52 PM
humiliategravity
I love getting replies in the first ten minutes... thanks guys.
Stock 73 radiator and ZZ4 engine with a new aluminum water pump. The coolant level actually was low - I topped it off afterwards. Okay good, maybe that was the cause.
As a follow up question, a ton of coolant had been spit into the expansion tank after only a few hundred miles of driving - is this normal?
Dave
Old Dec 6, 2004 | 01:29 PM
Garys 68's Avatar
Garys 68
Simple stuff first:
Coolant level too low
Fan clutch bad (my guess)
Thermostat not opening all the way
Water pump belt loose
Radiator needs cleaning/flushing
Could also be due to engine generating too much heat;
Too much ignition timing
Carb running lean
Old Dec 6, 2004 | 03:04 PM
Missileman's Avatar
Missileman
I agree with Gary's68. Lean carb is what I guess after the simple stuff.
Old Dec 6, 2004 | 03:11 PM
NHvette's Avatar
NHvette
The expansion tank should accept coolant when it expands (heats),
and allow the coolant to suck back in as it cools.
Maybe you have a bad radiator cap, or the coolant overflow
tank is missing a hose. If it's a plastic one like my 75, then the
cap has a hose that should extend down into the tank. If you
are missing this hose - or too short, you won't be sucking the
coolant back in.
Old Dec 6, 2004 | 03:50 PM
Boofers's Avatar
Boofers
This could be the case if your float is set too low.
Old Dec 6, 2004 | 04:17 PM
humiliategravity
coolant back in.
My tank is indeed missing the hose that sticks down into it. I was wondering about that.
When I emptied it yesterday, there was a ton of sludge inside the expansion tank. Amazing amounts actually. Any ideas where that came from?
I'll look into the lean carb issue. Seems like that would be something that effects the engine regardless of the uphill/downhill though.
Thanks again for the replies!
Dave
Old Dec 6, 2004 | 04:21 PM
Fevre's Avatar
Fevre
Get the hose replaced in the cap, you rad is sucking air back in when it cools down. The crude is prolly being steamed off the sides of the tank when the hot air (steam) from the rad is let out by the cap into the tank. You prolly do have air in your system causing your funny ready when going up hills.
Old Dec 6, 2004 | 08:41 PM
stingr69's Avatar
stingr69
Too little timing will cause overheating, not too much timing.
The sludge may be from the coolant mix. You have to be careful what type of coolant you use these days as they are not all the same type anymore. The old stand by yellow stuff should not be mixed with the orange stuff or the other stuff. If you have the sludge in the cooling system it is probably from mixing the coolant.
-Mark.
Old Dec 6, 2004 | 08:48 PM
humiliategravity
Since my car never sees freezing temperatures, I was thinking of replacing the coolant with 100% water. I've heard it's a better coolant as long as you're not below freezing.
I'll probably flush the whole system and see how it goes. Thanks all.
DB
Old Dec 7, 2004 | 07:46 PM
BigBlockk's Avatar
BigBlockk
Antifreeze has lubricants in it for the water pump and corrosion inhibiters.Always a good idea to run antifreeze. I think you need to take the radiator out and have it rodded out.
Hope this helps.
BigBlockk
Later.....
Old Dec 7, 2004 | 09:52 PM
NHvette's Avatar
NHvette
I think you are fine, once you replace that piece of hose.
Sludge could be oil leak or mixed coolants, but not just in the overflow.
Like Fevre said - coolant out - air in.
After a few cycles, you are low enough to get air to the water pump when going uphill.
When (if) you drain it, look carefully - any evidence should be clear,
like oil in the coolant.
Funny - I just noticed - is that gravity has humiliated you in this case!!
- Dave
Old Dec 7, 2004 | 10:32 PM
humiliategravity
- Dave
LOL... Well played.
Old Dec 7, 2004 | 11:57 PM
71coupe's Avatar
71coupe
I would say timing too. Going up a hill the timing will be less due to lack of vacuum for the vac advance, unlike driving on a flat road. Also, make sure the lower hose is not collapsing - there should be a large spring in it to prevent this.
To Engine overheats while going uphill...?
