Speedo cable question
Old Dec 6, 2004 | 12:59 PM
Double Aught's Avatar
Double Aught
Default Speedo cable question
I have a brand new one. Do they come pre-lubed or do I need to do it before installation? If I have to do it, what is the correct procedure? Thanks.
Old Dec 6, 2004 | 02:42 PM
GTR1999's Avatar
GTR1999
The new ones I bought were already greased. You don't want to over grease them and have it work it's way up to the speedo head.
Gary
Old Dec 6, 2004 | 05:50 PM
Double Aught
Gary
Old Dec 6, 2004 | 08:14 PM
carl a's Avatar
carl a
there was'nt a heck of a lot of lube when i checked,before installing mine last mth. i got a tube of cable lube and ran some inside ,,------------------
Old Dec 6, 2004 | 10:04 PM
Double Aught
Ok, did you use a drill to turn the cable? I am guessing that is the only way to work the lube into the entire cable. I just looked at the cable again and it has no lube in it. I "won" it on ebay. I will be heading to the parts store tomorrow to get me some of that graphite lube. Oh, I posted the same question on chevytalk.org and was told to get graphite lube, not oil-type lube. Also, the guy said to make sure and be very careful with that lube, cause it gets all over things if you aren't careful. Thanks for the replies.
Old Dec 6, 2004 | 11:26 PM
carl a's Avatar
carl a
thats exactly what kind i used. i took the two halves apart, and put a thin coat on the inners then reassembled, put in in the speedo first. then i turned it with my dwalt battery drill, making sure that the needle moved(seated) then i stuck the other end in the tranny
Old Dec 7, 2004 | 12:45 AM
Double Aught
Right, I just pulled out the cable part and it is dry, so most definitely it will be lubed, maybe tomorrow, weather permitting. I don't have an enclosed garage. Thanks for the tip.
Old Dec 7, 2004 | 12:49 AM
Cali,68,L-79's Avatar
Cali,68,L-79
What Vette do you own now and how come I'm so far behind!!!
i bought the 90 degree angle for the distributer and it already has the zirc fitting and even with new cable I pre-lubed it and 2500miles so far so good.
Old Dec 7, 2004 | 01:45 AM
Double Aught
No Vette, but I won a 67 396 Impala on ebay in Sept. I have been collecting parts and will be finishing the interior very soon. It is about 90 percent restored, with the interior left to do. Once that is done, I will bring it by. I am making it a custom interior. It is sweet and the engine is a friggin monster. His estimate was 400-425 hp. The guy said it was in a Nova that he made four passes in on the quarter mile. The car ran a low 12 second for the best run.
Old Dec 7, 2004 | 08:57 AM
Crash80's Avatar
Crash80
I found white lithium grease to be better than graphite...for what it is worth.
Old Dec 7, 2004 | 11:04 AM
Double Aught
Yes, that is another alternative. I think the factory one is greased witht that.
To Speedo cable question
