12 volts for timing light?
Dec 6, 2004 | 04:04 PM
I have a 1976 with L48 motor and 4 speed. Where is a good spot to grab 12 V. for my brand new timing light?
It has the clamp that goes around the plug wire and then the other two for ground and 12 V.
thanks
Dec 6, 2004 | 04:10 PM
Pull the rubber boot back from the alt and clamp the postive to the post, neg can clamp to almost anything metal on the eng.
Dec 6, 2004 | 04:11 PM
the large wire on the back of alt. is a good place. just pull boot back and there it is.
Dec 6, 2004 | 04:12 PM
thanks for the quick response guys
Dec 6, 2004 | 04:30 PM
Great question and great replies ! I have wondered about that myself.
Dec 6, 2004 | 05:01 PM
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
How bout this for a how too?
Dec 6, 2004 | 05:19 PM
Quote:
That pic is perfect, just missing one thing: the plug wire sensor melting on the header tube.
At least that's how mine is usually set up
Dec 6, 2004 | 05:29 PM
Ask tsw71 about that one!
His caught fire during a cam break-in on my 78.
-Steve
Dec 6, 2004 | 08:26 PM
You can hook up the pickup on the No.1 wire close to the distributor cap. No need to burn the wire on the headers when hooked up that way.
-Mark.
Dec 6, 2004 | 09:17 PM
I have always used the +12v terminal for the horn relay (located on the inside left fender).....this is safely away from headers & other heat sources.
Dec 6, 2004 | 10:29 PM
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Quote:
Same here. Except I did try to use the 12V lead on the coil...once...ok, maybe twice
Dec 6, 2004 | 10:42 PM
Bet that was a shocking experience.
