1/2 shafts and u-joints
Old Dec 7, 2004 | 06:03 PM
agteacher's Avatar
agteacher
Default 1/2 shafts and u-joints
1st----which is the BEST (stock vette-non-racer) u-joints for the 1/2 shafts. greasable--or--non-greasable
2nd----does it matter (when installing) about the EXCAT position of the 1/2 shaft to the diff. and trailing arm.
(80vette--auto)
THANKS
Old Dec 7, 2004 | 06:47 PM
71coupe's Avatar
71coupe
Non-greasables are stronger, but probably won't make a difference in a low perf application.
Old Dec 7, 2004 | 06:53 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
For "low" performance applications (I'd say around 300HP) the "low buck" AutoZone U-joints are just fine. They're about $14 a piece and mine did not break so far... knock on wood...
Old Dec 7, 2004 | 08:28 PM
agteacher's Avatar
agteacher
What about REINSTALLING 1/2 shaft-----right----wrong way????????
Old Dec 7, 2004 | 08:38 PM
Gordonm's Avatar
Gordonm
No it does not matter how they go back in. The 1/2 shafts when going around corners rotate at different speeds so they will not stay in the position you put them in.
Old Dec 8, 2004 | 09:44 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
To 1/2 shafts and u-joints
