M20 Trans. fluid??
Old Dec 8, 2004 | 09:05 PM
roger's 2937's Avatar
roger's 2937
Default M20 Trans. fluid??
I just finished inspecting and installing new o-rings and gaskets in my M20 and was wondering what you guys recommend for fluid these days.
Thanks, Roger B.
Old Dec 8, 2004 | 09:16 PM
lostpatrolman's Avatar
lostpatrolman
I put full synthetic in mine. Didnt seem to make any difference. I know alot of the newer trans just use normal atf, not sure if that is ok with an m20 though.
Old Dec 8, 2004 | 09:21 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
I put Mobil 1 Synthetic in my M20 two years ago.
Old Dec 8, 2004 | 09:32 PM
LOTAHP's Avatar
LOTAHP
What weight !!!??? M-20 should be using at least a 75w oil (gear lube). If synthetic comes in that weight then AOK.
I have always used a premium gear lube 75w and would change at least once a year. LOTA guys forget to change the manual trans. fluid on a regular basis (not every 3,000 miles )
Old Dec 8, 2004 | 09:35 PM
lostpatrolman
hmm.. I used 75w90 royal purple.
Old Dec 8, 2004 | 10:18 PM
LFZ's Avatar
LFZ
is it straight 75w? or 75w90? excuse the ignorance, but I wanted to know this also.
Old Dec 9, 2004 | 07:45 AM
pws69's Avatar
pws69
Same here. Shifts smoother and is generally MUCH quieter.
Old Dec 9, 2004 | 08:02 AM
bracketshark's Avatar
bracketshark
I'm trying to figure out where do O-rings go on a muncie? I haven't been installing any on my rebuilds.
Old Dec 9, 2004 | 08:37 PM
roger's 2937
Thanks for the replies!!
Roger B.
Old Dec 9, 2004 | 09:05 PM
LOTAHP's Avatar
LOTAHP
What weight ????
To M20 Trans. fluid??
