68 and 69 differences
Old Dec 9, 2004 | 03:03 PM
The Saint's Avatar
The Saint
Originally Posted by Corz
I almost bought a 68 but couldnt figure out how to open the damn door
Well until you install the Shark gill inserts, yours looks like a little like a '68 at least...
Old Dec 9, 2004 | 03:34 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Originally Posted by corvettecris
I have a 68, and I love all the unique one year only thingies.
Old Dec 9, 2004 | 04:38 PM
John 65's Avatar
John 65
I would like a 68 over a 69, although most 68's I see have all those little rivet bumps trying to break through the top of the body in the nose area. Whats up with that?
Old Dec 9, 2004 | 05:01 PM
wildman378's Avatar
wildman378
He was bragging about his not having this problem, he said most 68-69's are bad to crack around the pop up lights nad showed that his doesn't and has never had this problem so I have heard that also.
thanks for all the thoughts I've looked more into the differences and it's pretty much a carry over fomr 68 to 69 IMO I do like how the 69 has stingray on the side but I DON'T like the chrome gill inserts that looks a little cheesy to me.
either one is nice and wouldn't matter to me which I found just as long as it ws a convertible 4sp big block
Old Dec 9, 2004 | 05:27 PM
early shark's Avatar
early shark
Another difference is the exhaust piping, 2 1/2 inch for '68 bigblocks and 2 inch for '69 bigblocks.
Old Dec 9, 2004 | 05:35 PM
wildman378's Avatar
wildman378
Thats weird, looks like that would have cut hp a tad but maybe it increased torque a tad.
Old Dec 9, 2004 | 06:05 PM
early shark
Wildman:
It is true, L36, L68, L71, L88, ZL1 all came stock from factory with 2 inch piping only in 1969.
1970,1971 LS5, LS6 came with 2 1/2 inch piping.
Old Dec 9, 2004 | 08:01 PM
sammyb's Avatar
sammyb
The grill inserts were actually a $21 option. Mine doesn't have them, and actually, less than 1/3rd of '69 production had them. (Just shy of 12,000 cars had them.)
Again, the differences in 68 and 69 are so minimal, I would be more concerned with finding a great car at a great price than picking one year over the other...just my opinion, though.
Sam
Old Dec 9, 2004 | 09:03 PM
68/70Vette's Avatar
68/70Vette
Originally Posted by Garys 68
Lots of 1 year only parts:
Also add????
Unique manual master brake cylinder (It has built in bleeder nipples) The C2's and 1969 and up Corvettes had different master cylinders.
stamped thin steel valve covers for the SB engines, chromed for the 350HP engine. I understand these steel valve covers are unique for the 1968's.
unique cannister fuel filter below the carb. I think the fuel lines and vapor return were also original.
The plastic front grill pieces were all black plastic. In 1969 they were painted with aluminum paint leading edges.
My 1968 just has a crude bare light bulb in the storage compartment. I think other year Corvette's had a proper standard white plastic lens in the center/top of the compartment.
also I suspect the windshield wiper system was also unique in that it didn't work very well. It was changed for 1969 and up. My 1968 windshield wiper system was flawed. I'm going to try to make it work again if I can.
The factory supplied hard top for my convertible just simply didn't fit. It was slightly askewed and it "banged" around on bumpy roads. I stopped using it. It would have taken a substantial effort to make it fit.
Old Dec 9, 2004 | 09:17 PM
A C's Avatar
A C
Cruise-In II Veteran
That is the radiator core support rivets that come loose and start working their way out of the fiberglass. Notice their uniform location. Kinda like nail heads working their way out of drywall. They can be repaired fairly easily, but you obviously will need to repaint at least that section.
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Originally Posted by Paul Borowski
1968...
Unique steering wheel
nope 67 and 68 are the same
Old Dec 9, 2004 | 09:31 PM
Love My 72 and 77's Avatar
Love My 72 and 77
That answers a question I was scared to ask! Thanks
Old Dec 9, 2004 | 10:52 PM
  #33
lostpatrolman's Avatar
lostpatrolman
Mine has that problem, how do you fix it? Take the support off, bond it to the nose, then grind down the raised areas?
Old Dec 9, 2004 | 11:03 PM
  #34
A C's Avatar
A C
The guy that did mine (back when I was in my teens and my dad owned my Vette) just ground down the surrounding area, re-riveted the support, re-glassed the ground down parts and repainted it. He was a crappy painter, but it's 15 years later and the front still looks nice and smooth.
[edit - I just talked to dad....the guy didn't even re-rivet it. He just left the original rivets in and went over them with body filler.....and then did the rest. 15 years later and it still looks smooth]
Old Dec 9, 2004 | 11:08 PM
  #35
Cali,68,L-79's Avatar
Cali,68,L-79
1968...
Key on dash
7" Wheels
All Red tailights
Reverse lights below bumper
Smooth center cluster gauge bezel
Push Button door handles
E-Brake console has seat belt buckle pockets
One year radio *****
One year door panels
Coupe coutesy lens
plus a hundred more that I'm too tired to list
Paul you just about hit it. I love my 68 and she's been a trouble free car!!
