69 seat belt options
Old Dec 8, 2004 | 09:48 PM
1969c3mandy's Avatar
1969c3mandy
Default 69 seat belt options
Did 69 have retractable belts or standard lap belts? Were shoulder belts an option?
I am trying to get correct belts and I beyond confused...
Old Dec 8, 2004 | 10:28 PM
cart3113's Avatar
cart3113
I have been confused on this myself. The assembly manual shows seat belt as standard and the shoulder harness as RPO A85. I haven't been able to confirm if they were retractable. I have a friend that I will see Saturday he is big into NCRS. I will find out from him.
Old Dec 8, 2004 | 10:42 PM
lostpatrolman's Avatar
lostpatrolman
I always thought shoulder harness were standard for 69
Old Dec 8, 2004 | 10:46 PM
CruisinCO's Avatar
CruisinCO
I'm 99.99% sure they were std in the coupe and a rarely bought option for verts... My 69 vert is lap only.
Old Dec 8, 2004 | 11:07 PM
1969c3mandy
Default well....
I've always been told that shoulder belts were standard on 69s but I always see lap belts, even on show cars..anyone have a pic?
Old Dec 8, 2004 | 11:12 PM
CruisinCO's Avatar
CruisinCO
Okay I looked on the 1969 registry and as I mentioned above, std on coupes and only 600 of the 16,633 verts bought the shoulder belt option...That's why you see so many w/o it.
Old Dec 8, 2004 | 11:19 PM
cart3113's Avatar
cart3113
Were they retractable??
Old Dec 9, 2004 | 10:05 AM
BeaterShark's Avatar
BeaterShark
The shoulder belt is retractable. The lap belt is not. The two are not attached as the shouldber belt "clicks" into the lap belt.
Old Dec 9, 2004 | 10:44 AM
1969c3mandy
Default ?
how does the shoulder part install? I know where the holes are for the lap part..
Old Dec 9, 2004 | 11:03 AM
BeaterShark
The shoulder belt has a sort of "mushroom" peg that fits in the hole of the lap belt. Then, you slide it in the connected slot and it will "click" in place.
I can probably get you some pics if you want.
Old Dec 9, 2004 | 12:20 PM
tshort's Avatar
tshort
CI 7-8 Veteran
Here is where the attachment point is in the '69. You may not have the bolt but the threaded hole should be there underneath the carpet.
Old Dec 9, 2004 | 12:46 PM
Burgundy 69's Avatar
Burgundy 69
My 69 coupe (late) has the original belts. The shoulder belts are on retractors (the retractor mechanism and belt has a flexible plastic boot covering the unit) and bolt into the rear wheel well as in the picture posted above. They pull over the top of the seats and through a guide that is under the head rest. The latch has a post which locks into a corresponding hole in the lap belt.
The lap belt passes from the door towards the console and has a slider used for adjustment. My memory says that there were several styles of latch mechanism used on 69s. I believe that early models used the same mechanism as the 68. The later 69s (mine) used a smaller latch mechanism and it was mounted in a plastic sheath which held it up at the seat level and prevented the latch from dropping down between the seat and console.
Mark
Old Dec 9, 2004 | 01:29 PM
cart3113's Avatar
cart3113
Thanks for the info guys. I have the guides on the headrest and found the bolt hole in the wheel well. I found this site http://www.andoauto.com/Corvette.htm
prices don't look to bad considering the rebuild average starting price is $450. Tshort your interior is beautiful.
Old Dec 9, 2004 | 05:22 PM
Larry B.'s Avatar
Larry B.
I have an Oct.69 car.. The shoulder belts have retractor and go through the guide on the seat back. The buckles are both metal and the the lap belts store in a clip on the front of the seats. (No lap retractors)
Old Dec 9, 2004 | 06:57 PM
1969c3mandy
Default tshort
where did you get those belts? they look new..
To 69 seat belt options
