Dull, Dull, Dull
Old Dec 9, 2004 | 12:16 AM
MyFirstVette'80's Avatar
MyFirstVette'80
Default Dull, Dull, Dull
Check out the wheels on the '80 I bought awhile back. I like those stock rims, but I obviously need to make them shine. How??
http://www.imagestation.com/mypictur...ption=DSC03211
Old Dec 9, 2004 | 01:50 AM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
I was in the exact same situation as you are. My rims were sun beaten for 10 years, but now I have them looking this this.
I used a fine grit sand paper material. I think it was called emery cloth, or something like that. I used that until absolutely everything was sanded down. And then I scrubbed it down EXTREMELY well with Mothers MAG Polish. I believe I got this idea from someone here in the forum. All of my rims turned at GREAT! If you want, I can try to find some of the cloth and tell you exactly what grit I used.
Old Dec 9, 2004 | 02:32 AM
comp's Avatar
comp
it's winter time to get to rubbin'
Old Dec 9, 2004 | 07:31 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I used paint stripper for the clearcoat (most of it was chipped off anyway), then very fine scotch brite, emery cloth is very good,too.
I tried several aluminum and chrome polish products, Mothers is the best for a shiny finish.
Are you going remove the tires and the valves ? You could mount the wheels on the rear axle (the car on jacks of course) and let them spin, that will make the polishing easy.... have to be careful though....
Old Dec 9, 2004 | 08:57 AM
MIKER's Avatar
MIKER
Originally Posted by RedBad1979
....You could mount the wheels on the rear axle (the car on jacks of course) and let them spin, that will make the polishing easy.... have to be careful though....
I don't recommend doing this. When you lift the rear end off of the ground the angle of the half-shafts is too great, causing the U-joints to bind. I tried it ONCE a long time ago :o
Old Dec 9, 2004 | 09:25 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I agree, I did it (kind of successful) on a FWD a few years ago ..... didn't think about the half shafts...
you could however place the jacks under the trailing arms....
Old Dec 9, 2004 | 10:02 AM
Marv's Avatar
Marv
A product called "Never Dull" or "Nev-r-dull" is sold at O'Reillys and works well. It is a cotton wadding that has polishing compound in it. Lots of elbow grease and a finish polish with Mothers will really shine them up. BTW some folks pay to get their wheels to look dull since that is the correct, original look for some years. Have fun.
Old Dec 9, 2004 | 10:25 AM
MyFirstVette'80
Thanks, I'll give it a shot.
Old Dec 9, 2004 | 01:02 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I use blue magic!! That stuff is great!!
I got my wheels from looking like that:
to making them look like this:
Old Dec 9, 2004 | 01:09 PM
FB#1's Avatar
FB#1
I like the Blue Magic, I seem to get a better looking finish with it. Go thru a ton of rags though.
Old Dec 9, 2004 | 03:31 PM
Tim Parker's Avatar
Tim Parker
I used acetone to get the remaining clear coat off my 81s wheels. Then broke out the Mothers to shine them up. Use brake calipair paint to repaint the slots.
Old Dec 9, 2004 | 03:53 PM
bams12's Avatar
bams12
Mothers aluminum polish , a bag of soft rags and alot of elbow grease. I took my '80 aluminum wheeels from dull to bright shiney finish !!!! Mother 's aluminum polishnis the key .... Brent
Old Dec 9, 2004 | 05:18 PM
Pauld's Avatar
Pauld
I did this on my 81's stock rims before I replaced them with my TTII's. I removed the clear coat and then used a fine wet and dry paper to get them smooth and reasonably shiney. I then used a polishing mop and polishing soap until I had achieved a mirror polish. Took sometime but was well worth it in the end.
Old Dec 9, 2004 | 05:40 PM
'77BABE's Avatar
'77BABE
I use Never Dull to clean them, takes a while, but it works. Then some polish that's for chrome on motorcylces. Don't know the name though (the label's gone), but it works!
Old Dec 9, 2004 | 06:13 PM
Megawatt's Avatar
Megawatt
Hand rubbing is for the birds. I used a 4" angle grinder with a 4" or 5" buff and Mother's.
If they are really rough you might use emery and then progressively finer abrasives with the last being 1500 wet dry and then power buff them with mothers.
In order to use a buff I had to make an adapter using one of those long nuts. There is a term for the "long" nut but I forget what it is. Maybe it's a "coupling" nut. You can get them at Home Depot et al. You are going to have to polish them from time to time so you might as well come up with a power solution.
Now that I have my BC Smoothie II's I'm thinking of trying that flexible shaft buffer I saw in Eastwood's catalog. I will buy the motor else where. They wan't too much for the motor. Heck they won't too much for the flexible shaft also but I don't know where else to get one.
Old Dec 9, 2004 | 06:19 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
I can't believe you guys polish these things. After a few days mine are black with brake dust and look like hell.
I use the porus wheel acid etch cleaner that releases brake dust by just spraying and hosing off. Leaves the wheel with that stock looking grayish sliver finish.
Old Dec 9, 2004 | 06:42 PM
'77BABE's Avatar
'77BABE
That's how my dad used to do it. It's easy, but I prefer them polished.
To Dull, Dull, Dull
