Just installed the Pertronix II flamethrower coil,
Maximum Voltage 45,000
Turns Ratio 110:1
Primary Resistance 0.600 ohms
Secondary Resistance 10K ohms
Inductance 5.5 mH
Peak Current 7.2 amps
Spark Duration 1.5 mS
And I already had the P-II ignition module but still had the ballast resistor attached. I removed the ballast and installed the new coil and she fired right up on first try! Ususally she sluggisly starts and there has to be some pedal movement involved to start. I think it's not so much the coil but the fact that the ballast is removed which allows the full current load to hit the coil for a greater discharge. I'll see if the car responds better tommorow when I drive her to work.
Are those specs better than these?
Peak Current 140 mA
Spark Duration 350 uS
Are you sure the peak current of 140mA is correct?
It seems to make sense to me that the spark duration of 1.5ms is better (350us is only 0.35ms, 1.5ms is 1500us).
The other parameters like turns ratio, resistances, etc. aren't really different enough to have any significant benefits/drawbacks but I would say 'on paper' the flamethrower is slightly superior.
Maximum Voltage 58,000
Turns Ratio 112:1
Primary Resistance 1.400 ohms
Inductance 6.6 mH
Peak Current 180 mA
Spark Duration 300 uS
Both the MSD and Mallory have higher primary resistance that the Pertronix so, they have a weaker spark as all the coils seem to have the same secondary resistance. I have used Pertronix since they were marketed under the "Perlux Ignitor" brand back in the 1980's and have had excellent performance with their products on all my "vintage" cars (Mustangs included!) The coil in the photo is the "epoxy" coil with no oil that works very well on extreme applications such as off-road "Baja 1000" type applications. I use the epoxy coils for vintage race cars with excellent reliability.
