torque converters , how much stall
Old Dec 11, 2004 | 10:42 PM
trackdogg's Avatar
trackdogg
Default torque converters , how much stall
running a 350,9 to 1 comp.,duration on cam is about the same as the L-82, has 3.73 gears, and a TH400.
Old Dec 11, 2004 | 10:48 PM
slarsen's Avatar
slarsen
I would stick with the stock converter. Your setup does not justify going to a higher stall converter. Unless all you are doing is stop light to stop light you will get very tired of a non-stock converter stall speed.
A slight increase in stall will help, but your car will not be that much faster........just burn more gas
Old Dec 11, 2004 | 10:49 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
how are you going to drive? drag strip...street...etc....
why isn't the stock 1600 rpm stall speed good enough?
Old Dec 11, 2004 | 11:18 PM
GregG_BB_Stingray's Avatar
GregG_BB_Stingray
8th Gear
Default comp ration & mild cam
With 9.1:1 comp ration, most your power is at the lower rpm, so there the lower rpm lanch stall from factory is prob best. The other reason of a higher rpm stall is trouble at idle with a radical cam, so again it would be a waste. Looking for more power? Dome pistons to bring up the comp ratio a little, larger exhaust valve heads, headers, edelbrock performer rpm intake manifold, little more cam, and a proper sized carb to complete the tune. Just search the internet for "build up" on what ever engine you have. They will often provide a part by part and the result you should expect in the article.
GregG
Old Dec 12, 2004 | 12:04 AM
isosceles's Avatar
isosceles
When I had my 2004r installed, I went to an 1800 stall connvertor. So far with the L48, it was not worth the money over stock. I can powerbrake to 1600 instead of 1300, but so what!
I'll have to see with the 383 how it behaves.
To torque converters , how much stall
