Front Spring Question
Old Dec 12, 2004 | 04:31 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Front Spring Question
I have disassembled the front end of my 1980 and am preping for the rebuild. Per the photo below, the springs I reveived from VANSTEEL are quite a bit shorter than those I took off the car. I have sent Dan an email at Vansteel and am certain that I will receive a reply. In the meantime, does anyone have any idea about this? Are the new springs an upgrade? I don't want to change the ride height...so I guess I could use replacement springs if the compression rate is different...
Any help would be greatly appreciate...
Ed
Old Dec 12, 2004 | 06:02 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Measure the tickness of the new spring compared to the old spring. I bet the new spring is thicker. Mine were. And the spacing between the coils is larger.
Old Dec 12, 2004 | 06:44 PM
gearheadz's Avatar
gearheadz
Your stock springs are probably a lower rate so they compress more under load than the Van Steel ones. So their final height once under the car is probably very close. My springs (stock & VB&P 460s) side by side looked very similar to yours and the final ride height is the same.
Old Dec 12, 2004 | 08:35 PM
mavrick331's Avatar
mavrick331
My new ones were shorter has well, replaced mine this summer, ride height was the same, if not a hair higher.
Old Dec 12, 2004 | 10:46 PM
NHvette's Avatar
NHvette
If you go the the local parts store (like me), the replacement
springs are now 440lbs (about the same as 460).
They are shorter and higher rate ... should sit the same if installed correctly.
If anything, you may find they sit high. Many here have cut them
down a 1/2 coil or so to "get 'em just right".
Oh - yeah - just like the post above.
The good thing ... they slip right in without a compressor.
The stock springs can go in without a compressor, but it is a fight
to wrestle them in correctly.
Old Dec 13, 2004 | 08:01 PM
80TexasC3's Avatar
80TexasC3
Thanks Everyone... sounds like I should be OK... One final question...
What would be better: Drill out the old Rivets that hold the ball joints on or grind them off?
Old Dec 13, 2004 | 08:42 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
From what I've read, probably a combo. Grind off the head, drill out the shaft.
I'll also add to the chorus... I replaced my stock for VBP 460's and they were much shorter, but the ride height actually came up a hair.
Old Dec 14, 2004 | 08:46 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
The long ones that came in the car(original ones)are exactly like the ones I have had for sale in the C3 parts forum for $50, only they are new NOS GM ones. These shorter ones may work, usually aftermarket springs are sometimes a hit/miss with them.
Old Dec 14, 2004 | 10:19 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Spring replacement
When I replaced the original springs in my 70 with the GM 518 optional suspension spring, the springs looked similiar to yours. There was no change in the ride height. The stiffer spring was an improvement in the performance handling of the car.
Old Dec 14, 2004 | 10:31 AM
wcsinx's Avatar
wcsinx
I bet that makes installation easier!
Old Dec 14, 2004 | 05:07 PM
adam's Avatar
adam
Old one 10 coils, new one 6 coils.
I'm betting these are 460 or 550 lb springs.
Ride height may go down a little. I recall a 7 coil spring that I cut 3/4 off.
Do you have your air dam and spoiler attached?
To Front Spring Question
