71 Automatic wiring diagram needed
Old Dec 12, 2004 | 05:05 PM
majic1984's Avatar
majic1984
Default 71 Automatic wiring diagram needed
Alright guys and gals, I'm currently in the process of installing my engine, dash, and forward lamp harnesses for a 71 automatic small block. I'm having a good bit of problems with the diagrams I am following. I bought the following wiring diagrams: http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW and a 71 Chevrolet Chassis service manual (shop manual) - I don't have the Factory Assembly manual. The thing is... the wire colors on the harness I have match up perfectly with my old harness's but on the wiring diagrams, the colors on the main plugs don't even match . Can anyone please help me with this?!
Thanks,
Michael
Old Dec 12, 2004 | 05:27 PM
majic1984's Avatar
majic1984
Could someone who has a factory assembly manual for a 71 please post the wiring diagram from it?
-Michael
Old Dec 12, 2004 | 06:50 PM
majic1984's Avatar
majic1984
bump
Old Dec 12, 2004 | 07:16 PM
Jack71's Avatar
Jack71
I would buy the diagram from lectriclimited.com There's is pretty accurate (although there are always minor deviations)
Old Dec 12, 2004 | 07:52 PM
majic1984's Avatar
majic1984
Minor deviations such as wrong colors on the main plugs? (ones that screw onto the back of the dash harness)? Because the ones I have right now don't even match the damn wire colors comming from the plugs at the start of the harness.
Old Dec 12, 2004 | 07:58 PM
Larry B.'s Avatar
Larry B.
Color codes do seem to change colors sometimes at certain plugs. I have a 71 GM sevice manual and I will find the diagram but i can't do it until tomorrow. try www.alldata.com and look for service manual
Old Dec 12, 2004 | 08:11 PM
majic1984's Avatar
majic1984
Originally Posted by alldata.com
At this time we cover model years from 1982 to 2000
Thanks a lot for looking it up in your manual though, you guys are the best!!!
Old Dec 12, 2004 | 10:40 PM
markdtn's Avatar
markdtn
Not sure what you mean that the colors on the plugs don't match. GM is very good about keeping wire colors constant through the years. The position on the fuse panel/firewall bulkhead passthrough of the wires varies year-to-year but the wire colors remain constant. Are you sure your new harness is for the correct year?
Old Dec 13, 2004 | 12:02 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
The back of the instrument and speedo cluster is normally stamped with the wire colors at each connection.
Old Dec 13, 2004 | 11:05 AM
majic1984's Avatar
majic1984
I'd have to show you what I mean... I am sure that I have a 71 corvette, I'm also sure that it is the right harness. My new harness matches my original harness perfectly except a few connections that have been slightly modified, however, according to the wiring diagram (I'll post pictures of everything later on today) the wires comming out of the plastic block that is "C" shaped (that connects to the back of the fuse box) on both engine harnesses (original factory harness and the one I just bought) aren't even in the right place?!
- Michael
Old Dec 13, 2004 | 12:53 PM
markdtn's Avatar
markdtn
That's what I was referring to. If the wire positions on the fuse box don't match the one you are taking out then the harness is not the same. There are 2 possibilities for this:
1) They sent the wrong year harness to you. Honest mistake.
2) You have the wrong year harness in the car now. 69-71 (and 72 if you don't mind not having fiberoptics, and 73-75 if you don't have a wiper door either) harnesses will interchange if you use the whole thing from the donor car. I have a 72 harness in my 69. I added the fiberoptics.
Bottom line: If your pin positions don't match you need to find out why. Do the pin positions on the new harness match the factory wiring diagram? I think your original post says no. Does your new harness match the old location-for-location? If the pins on the new harness match the wiring diagram, you have the wrong harness in the car now. If the pin locations don't match the diagram, then the new harness was packed wrong and is for a different year.
Old Dec 13, 2004 | 01:15 PM
majic1984's Avatar
majic1984
They do match.
Nope. Well, to tell you the truth, I don't know as of now because I only have the diagrams from www.classiccarwiring.com and the shop manual.. I'm still trying to get a diagram from the Factory Assembly Manual.
Yes
Maybe this is a possibility, however, what are the chances of getting matching harnesses, but both are from the wrong year? By the way, there are stickers attached to each harness labeling them. The engine harness says "71 Corvette Engine Harness, Automatic"
- Michael
Old Dec 13, 2004 | 02:57 PM
markdtn's Avatar
markdtn
You can read the pin locations from the shop manual wiring diagram. That's all you really need.
The "C-shaped" part of the harness was used on many GM cars from early 60s into the 80s so it is hardly unique. So it will physically interchange even if all the wires are in the wrong locations. The only difference in a 68, 69, 70, and a 71 Corvette engine harness is pin locations and horn buzzer wiring (same goes for 72 except fiberoptics). If your wires are not in the same location on the new harness as the old, they are from different years or wired wrong.
edit-68 is different due to alternator wiring.
Old Dec 13, 2004 | 05:49 PM
majic1984's Avatar
majic1984
Called M&H and verifed the harness. Nothing is wrong with it, it's the correct year. Apparently some of the wiring diagrams for these cars were made 1 year in advance of actual production of the harnesses, therefore creating major differences. I have a copy of the factory assembly manual diagrams now (they look different from both of the ones I've got). I will compare those to my harness tonight and tell you guys whats going on. Thanks for all your help, wish me luck. *crosses fingers*
-Michael
Old Dec 13, 2004 | 06:14 PM
Larry B.'s Avatar
Larry B.
I looked through what is left of my 71 GM manual.. There are a few pages missing but there doesn't appear to be a full schematic. Just for the A/C and some other car line accesories. I do however have a 4 page wiring diagram in a haynes manual that seems to be a copy of a GM manual. If you want that I will scan it and send it to you Via E-mail. let me know
Old Dec 13, 2004 | 07:13 PM
majic1984's Avatar
majic1984
Hrm, seems the Factory Assembly Manual's diagram matches my harness (colors and all) perfectly. I'm not sure if Larry B. has one of these diagrams, but the one the M&H guys faxed me is very poor resolution although I can barely make out what the colors say. I was wondering if anyone could make a hi-res scan of it for me please.
Thanks,
Michael
Old Dec 13, 2004 | 08:20 PM
majic1984's Avatar
majic1984
Here's the wiring diagram that I said was correct (Out of the factory assembly manual). If anyone has a clearer one like it for a 71, could you please send it to me?
http://members.***.net/gdeb/scan0003.jpg
Thanks,
Michael
To 71 Automatic wiring diagram needed
