Less tha professional (Bubba) fixes, how many?
Some mysterious reason ensured the less than professional repairs (bubba) never worked aft of the seats - lucky for me.
So to Rant and get it out'a my sysem i'm make'n a list of my less than professional repairs.
Mirrors - sport type and not original chrome - not a big problem except that adjustment **** digs into my leg.
Heater/AC box - no seals. Yep hot engine compartment air blows into P-compartment.
- Plastic ears just broken off the box held in with meteric 10mm sheet metal screws.
- No seal between htr box and windshield defroster ducting.
Engine - New GM goodwrench 350 wiped exh lobe on #4 with < 35k mi.
- All smog equip long gone (no big deal here).
- New MSD dist with tack drive cable smashed/broken against firewall.
- MSD 6A wired in wrong (probaly trying to cure the low rpm miss from wiped exh lobe).
- starter brace and stock heat shield gone.
- missing fuel pump casting bolt allowing engine oil to just leak out at will at front of block that should have covered the fuel pump rod.
- found broken engine mount also but that could have been the result of my no-longer favorite trans shop letting the engine hang during clutch R&R.
- all freon out of AC sys.
- wrong year core support and brackets.
- radiator leak from puncture of too long bracket bolt leaking coolant down to rot out wrong year core support.
- missing all but 1 shroud seals.
- oh yea that core support was missing a brace to the front bumber too.
- looked like just lug nuts used for self-locking nuts on the A-arm cross-bar bolts.
- yea that hood hinge bolt.
- and that safety wired d-side lower splash guard.
- cross threaded running board screws.
Okay thats 20 for me.
Ahhh, this feels better.
But ya know what feels best is when i gett'm fixed better than original. That way i won't be brake-down along side the road wait'n for AAA.
Feel free to add ur list here. cardo0
