New engine needed! Doh!
Old Dec 13, 2004 | 02:38 PM
74Thrasher's Avatar
74Thrasher
Default New engine needed! Doh!
Hey guys,
My '74 had been having a wicked backfire, and I thought it was finally fixed, but it came back with a vengeance this weekend. Brought it to my mechanic, who told me that at the very least the cam is worn out, and that the engine needs to come apart to fully diagnose the problem. I'm too new to cars to do this myself, and I don't feel it's worth it to pay to have a rebuild on this motor, since it doesn't really perform all that well. So that leaves me searching for a new motor.
I was planning on replacing the motor a few years down the road when I had more technical knowledge, but I guess it's gotta happen sooner than that. So what do you guys think? LS1? ZZ4? ZZ383? I'm pretty open to suggestions. Thanks,
- Colin
Old Dec 13, 2004 | 03:06 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
There isn't any reason you can't rebuild your current motor with new internals that will give you the HP you want. With a new crank, it can be a 383. Personally, I'd rather have a local machinist rebuild my motor than go with a crate. That way, if anything goes wrong, you have a local person to go back to.
Old Dec 13, 2004 | 03:09 PM
Joe Buck's Avatar
Joe Buck
I agree, don't rebuild something that doesn't perform to the specs that you want it...I have an 80, had my 305 taken out, put in a 350 that outperforms a ZZ4; a guy who builds NASCAR engines did this for me...but I've heard very good things about the ZZ4 crate motor, look into it, or perhaps a 383 stroker motor...
Old Dec 13, 2004 | 03:22 PM
cart3113's Avatar
cart3113
It depends on what you do with the Vette. Just cruise, local shows, long trips, is it a daily driver? Do you want to keep the Vette numbers matching?
If your thinking of a LS1 then cost must not be a problem. You need to factor in what you want from the Vette and how you use it. Personally I think the crate motors are the way to go. Turn key install, warranty, good power, its the best bang for the buck.
Old Dec 13, 2004 | 03:26 PM
L88Plus's Avatar
L88Plus
I'd get a second opinion - he'd have to take the valve covers off and turn it over to check cam lobes, etc. I'd also want to check the timing chain as a lot of stretch can screw timing up pretty bad. You can drop a cam and new lifters in with a new timing set, new valve cover and intake gaskets for less than $200 in a day. Why go thru all the trouble of pulling an engine that hasn't been fully diagnosed yet? Just my .02
Old Dec 13, 2004 | 03:28 PM
page62's Avatar
page62
Isn't this the motor with 217K on it? There's no reason a decent machine shop can't do a rebuild, if that's what you want. It can be built up...to where it'll be better and stronger than new!
Old Dec 13, 2004 | 03:42 PM
CGGorman's Avatar
CGGorman
Why rebuild when you can go big?
Old Dec 13, 2004 | 07:25 PM
markdtn's Avatar
markdtn
Isn't that the whole point to a rebuild? To make it perform better? 74 should have a good bottom end to build up. Add good guts and heads and it would be fine.
Old Dec 13, 2004 | 08:07 PM
soggybottomboy's Avatar
soggybottomboy
If your current engine is toast, and your not savy about rebuilds and want more ponies then a crate motor is a good option. You'll get a big boost in your driver with the GM performance crate motor. If that's not radical enough there a plenty of 383 crate setups. My .02
Old Dec 13, 2004 | 08:16 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
REBUILD
Old Dec 13, 2004 | 08:18 PM
jdmick's Avatar
jdmick
Ya, I'll bet if you stomp on it you'd get all of about 20 feet until little pieces of shrapnel from all those wonderful u-joints, half shafts, and differential start sticking in you.
Old Dec 13, 2004 | 09:07 PM
stingr69's Avatar
stingr69
Rebuild it. If the bores are worn you should stroke it to 383 and add better heads. The cost for the stroker is not much over the cost of the stock overbore rebuild and the performance increase is well worth the effort.
If the bores are still servicable I would overhaul the bottom end and again put better heads on it.
Either way you get better than brand new performance and the personal satisfaction from a job well done. Match the new cam to the rest of the combo and C/R and you are good to go.
-Mark.
Old Dec 13, 2004 | 09:19 PM
74Thrasher's Avatar
74Thrasher
Thanks for all the replies.
Here's the thing: It really is not that strong of a motor in the first place. I would say, from the butt dyno, it doesn't pull much harder than my 265 lb/ft Maxima. And I don't really know what it the motot is, but it isn't the stock block for sure, and like I said, it's not really that strong. So what could I expect to get out of a rebuild with a new cam, heads, and stroking?
Old Dec 13, 2004 | 09:33 PM
markdtn's Avatar
markdtn
The sky is the limit--or is it your budget? Anyway, starting with the block and crank you have you could get a lot if you wanted.
Old Dec 13, 2004 | 10:36 PM
Desperado76's Avatar
Desperado76
My 76 is the one with 217k! She still going strong, knock on wood!
Brett
To New engine needed! Doh!
