I now have a working tach again,ill have the speedo working this week sometime when my speed sensor/speedo cable adapter comes.Now i need to get a vacuum guage to match it.
Thanks,Honestly havent given it much thought yet I might mount some kind of jeweled light some where so i can see them but not in direct view and hook the light to it.
Len, i didnt use the template,but i used the stock housing and cut the center out of it and drilled 2 holes in it to mount them.But the template would probably work great.I did have to change the speedo cable cause this one screws on and the old one clipped on.
That looks really good. I've been doing speedo and tach repair work on my Vette this last week. I wish I could do that to my car but that just won't work for me.
Patnitro,
We took the case off the speedo and tach and drilled small holes to insert LED's for the turn signals, high beams, and hand brake lights. You can add others as you see fit. You can label them, or cut the face of the Autometer guage in the form of an arrow or other symbol to make it look more factory.
