How to dye door panels?
I want to dye oxblood over red. Red door panels are new.
I too used a topcoat of clear (SEM) and it took the shine out of the black color I used. I LIKE IT!!!!
Also scratched off the dye to reveal the stiching.
Eddie
I can't wait to put it all back together. Every piece has been removed and either restored or replaced with new. It's getting close. Just a couple more items, if my wife doesn't kill me first! ($30 here, $50 there... it all adds up fast!)
And for the plastic parts, use a product called Bulldog. It is available at PPG paint and probably other supplies stores as well. Comes in a spray can and makes the dye stick to plastic, chrome, metal etc.
I used dye from Corvette America, came out perfect. you have to really clean it good then wipe down with alcohol. Get more than you need so that it is all from
iget it from corvette central or whoever uses corvette america-it will get shipped directly from corvette america after corvette central or who ever takes there chunk of dough out..!!. do you have a ''test piece''??? thats what i did to check the gloss of the clear coat and to check for ;;paint lift'' before spraying my sacred origional skinned pieces!!!!!
