That is the same eng I have, known as the GM Goodwrench Universal Engine or LM1. I put a little larger cam in when I got it (204/214 .424/.444 Summit brand) and was pretty happy for the $ spent. I then put alum heads with a roller cam (222/230 .560/.580) in it and it screamed pretty good, 13.4 in the qtr mile. I am putting it back in with the alum heads and another flat tappet cam (214/224 .444/.464). I think you could use this cam with the stock heads that come with it and see somehwhere around 300 hp. I am still hoping to get a stroker or 400 based eng going and wanted to have the roller cam avail for dyno testing so I did not put it in the eng.
BTW If you decide to put a diff cam in it before install you can reuse the lifters that come with it since they have not been used, saves you $20 or $30.
Chevy High Performance did a multistage buildup on one of these a few years ago. THe stock bottom end is OK. Can't remember the final numbers but it was impressive.
Myself and some others here are also looking at that engine. http://forums.corvetteforum.com/showthread.php?t=965979
What have you found for pricing? Summit gets just over $1400 plus around $100 extra shipping. My local chevy dealership wants $1500 pls $100 core.
I got one from a local dealer for my 4X4 truck rebuild about for years ago. I left it 'stock' except for headers, intake, carb. Absolutely zero problems in four years and it served as my daily driver for about three years. I called four different Chevy dealers in my area when I bought it, and the prices varied by about $300, so call around. I paid $1245 & picked it up at the dealership myself.
why not just buy a short block and start from there?
good idea, but I'd like to have something in there this Spring. The heads, pistons and cam will be installed after a couple of years...I mean why void the warranty on a decent engine?
PSSST, put a bigger cam in, GM will never know. I bet the head flow for the heads that come on it would warrant a dual pattern cam.
I am going to leave the bottom end alone and just use it for a spare eng when I decided on an eng to put in some time in the future, nice to have one to throw in just in case you blow one up.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
From: Las Vegas - Just stop perpetuating myths please.
Not worth upgrading.
Would it be a wise choice to purchase this engine as a replacement for my original L-48? Should I just store the original?
How upgradeable is this engine?
Anyone have one, and what mods have you done to it?
Just getting ideas, Les
I have a LM1 in my '74 and upgraded it only because it was/is still in the car and i had to R&R radiator & core support - opportunity to change cam (and install headers). The pistons are the weak link and not what i would push over 350 hp - but thats me. Those heads are wheezers too and deffinatly not worth moding to make power.
Only mods i would make is to elongate the push-rod slots for 1.6 rockers and install. Install 0.015" steel shim head gaskets for better quench and a little more desparatly needed compression. Then advance the stock cam a few degrees. So for less than additional $100 u might reach 300 hp at the flywheel with the stock ram exh manifolds. But it would run hard and race on forever. Start quietly and idle glass smooth too.
If u want to build ur own try PAW block kits. Short blocks $1100 for 350" and $1700 for long block kits with World Product heads (much , much better head). Stroker 383" short blocks $1600 and long block 383" kits for $2100.
Good luck. cardo0
