No Brakes Please Help
Old Dec 14, 2004 | 08:45 PM
drsleep's Avatar
drsleep
Default No Brakes Please Help
Brakes went out today for no apperant reason, brakes just go to the floor, changed master cylinder but no change somebody please help.
Old Dec 14, 2004 | 08:48 PM
Turbo-Jet's Avatar
Turbo-Jet
any puddles under the calipers?
does the balance light come on?
Old Dec 14, 2004 | 09:19 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
How did everything look around the calipers when you bled the brakes? Did you bleed both bleeders on each rear caliper? Did you bench bleed the master cylinder? If all that checks out then you may want to have a look at your proportioning valve.
Old Dec 14, 2004 | 09:54 PM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
This just happened to me. I blew one of the pistons seals in the front right caliper. Decided to just make a day of it and replace all four. Check your pads and rotor to see if you can find wetness. My guess is that you might find one of your pads looking like it just took a swim.
Old Dec 16, 2004 | 12:47 AM
drsleep's Avatar
drsleep
Default thanks
Thanks guys I checked everything and it was the front passenger calliper cylinder went out fluid all inside of the rim, made a day of it as per johnny4523's suggestion and changed all four and now she stops on a dime! thanks for all of the help !!
Old Dec 16, 2004 | 02:31 PM
jonny4523's Avatar
jonny4523
Just curious, who did you buy your calipers from?
Old Dec 16, 2004 | 02:57 PM
burners's Avatar
burners
Cruise-In V Veteran
Good job, I'm glad you got it fixed.
Old Dec 18, 2004 | 01:25 AM
drsleep's Avatar
drsleep
Default callipers
johnny4523 I got the callipers from Advance Auto Parts, had to go to a couple of locations to get all 4 but did get them
To No Brakes Please Help
