Electrical/wiring advice needed!!!
By no means is this project anywhere near finished, but the progress has been good, and the chasis, engine compartment, wiring, engine, trany, all suspension, brakes and everything looks great. I'm really happy with it so far.
Now for the concern. I've had all the wiring/harnesses removed at one point or another, and I marked everything quite well, and most everything seemed to have it's correct place to go back to, although there have been a couple of, "does it go here or there?"
So, to be conservative, with one lead of battery still disconnected, I put my amp meter in series with the pos lead of a fully charged battery with the key off. Got a reading of 130 milliamps.
Then I swithed the ign switch to the on position, and checked it again. I got a reading of 1.5 amps.
Both of those readings seem ok to me, although, since the clock isn't working, I'm more concerned about the key off reading. Maybe it draws some current even though it's not working?
The 1.6 amps in the "ready to start" mode seems fine, but I'm no expert on electrical stuff.
A few more things to hook up tomorrow, some radiator clamps, and a final review of my 6 page check list, and then I'm going to light it up.
Hope it runs!
Any thoughts on my electrical paranoia?
Thanks, Bill
Thanks, Bill
can you disconnect the clock totally...to see if thats the drain?
Did I understand your coil is attached? You'll draw about 1 to 2 amps if the points are closed. Just a thought.
Andy
