Noob tranny/rear end question
Old Dec 16, 2004 | 12:00 AM
76mike's Avatar
76mike
Default Noob tranny/rear end question
Question: My vette goes 65 in 4th gear at 3200RPMs. Is it just me, or is something wrong there??? Is this a popular thing??? I mean, I guess the back end is geared in such a way that it will go 8MPH when it's idling before I give it gas, and it doesn't seem like it could go very fast since it redlines at what, 5500 or so. Is this common??? What does it mean??? (I'm a noob so help me out )
Old Dec 16, 2004 | 12:21 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
it means you have a ratio in the rear end that was designed for acceleration for example (i'm making these gear ratios up) 3.99 or 4.11 as opposed to a 3.08...all our vettes suffer from this....thats why the conversion to 5spds or in my case an overdrive Auto is so common place....there are websites that can calculate your rear end ratio based on tire circumference,engine rpm and speed
Old Dec 16, 2004 | 02:04 AM
comp's Avatar
comp
Old Dec 16, 2004 | 02:34 AM
i885744's Avatar
i885744
http://marylandperformance.com/calculator.html
You've probably got 4.11:1 gears.
Old Dec 16, 2004 | 08:01 AM
GTR1999's Avatar
GTR1999
depending on tire size I'd guess you have 355 or 370 gears. Do you have an L82 motor?
Gary
Old Dec 16, 2004 | 10:20 AM
crazydalys's Avatar
crazydalys
The tach in my '76 is broken, but I know the engine does rev pretty good on the highway. By 30 mph I'm already in 4th gear. You proabably have the 3:73 rear end.
Old Dec 16, 2004 | 02:32 PM
76mike's Avatar
76mike
No it's not the L82, it's the L48. Just seems odd to me, is this a standard vette rear end?
Old Dec 16, 2004 | 02:44 PM
GTR1999's Avatar
GTR1999
A friend with a 76 complained about the same thing and finally pulled the rear end out. It had a 336 which what the WR 4 spd and base motor should have. He didn't like them and we installed 273's.Automatics came with 3:08 or optional 355's.
Gary
Old Dec 16, 2004 | 02:59 PM
L71Maynard's Avatar
L71Maynard
You can check the casting numbers on the bottom of the pumpkin and it will tell you what was in there new. Other then that only calculations will tell you what what gear is currently in there.
Dave
Old Dec 16, 2004 | 03:18 PM
Boofers's Avatar
Boofers
I have a 4 speed with a stock 3.36 rear end. My tires are 235/55-17 which have an approximate diameter of 27.2 inches. At 65mph my engine rpm is approx 3100.
Good tire size calculator
Old Dec 16, 2004 | 04:01 PM
rosslato's Avatar
rosslato
Old Dec 16, 2004 | 04:27 PM
adamdinat's Avatar
adamdinat
That sounds about right. It will take some time to adjust and accept.
A nice aspect of the 4 speed is you can lug it down on back roads without having to shift all the time. If you do a lot of highway driving you might want to consider a transmission change.
Old Dec 16, 2004 | 09:58 PM
69autoXr's Avatar
69autoXr
Something's not right here...with those numbers your engine should be turning about 2697 RPM at 65 mph. Or, if you're speedo is inaccurate, you should be cruising along at 74.7 mph at 3100 RPM.
Your numbers equate to a 3.86 gear.
mph=(rpm*tire dia")/(trans*gear*336)
No calculations are really necessary to know what gear you have...put the rear of the car on jack stands with the trans in neutral, mark the driveshaft and count how many turns of the driveshaft equates to one turn of the tire. That's your rear end ratio.
Old Dec 17, 2004 | 12:06 PM
Boofers's Avatar
Boofers
Its hard to imagine my speedo is off by that much but what else could it be? I wonder if my clutch/tranny/diff are slipping??? I'm replacing my clutch this winter and having my diff rebuilt as well, maybe I'll get some answers then.
Thanks for the good idea, its on the check list.
To Noob tranny/rear end question
