How does this engine deal look?
Old Dec 16, 2004 | 12:22 PM
jdmick's Avatar
jdmick
Default How does this engine deal look?
What do you guys think about trying one of these in my 75.
http://www.jegs.com/cgi-bin/ncommerc...21&prmenbr=361
It basically just has a different cam than the $1400 base engine. I know it's not exactly a 383 stroker but I'm trying to stay on a budget.
I've got the hooker headers and side exhaust and an Edelbrock Performer 1406 carb on my old engine. I'd probably go with a Performer intake and scrap the old Torker I.
What kind of real #'s do you think I would end up with? Thanks!
Old Dec 16, 2004 | 12:25 PM
LFZ's Avatar
LFZ
REAL numbers....probably not much. I'd say around 200rwhp at the most...its a good engine for a budget, but I wouldn't buy it for performance.
Old Dec 16, 2004 | 01:19 PM
jdmick's Avatar
jdmick
Tell me if this is about how you calculate RWHP. I assume the 290 HP is SAE gross. If you figure 20% (?) loss from gross to net that brings it down to about 232 HP at the flywheel. Then if you figure about 15% (?) loss for the driveline for an auto you get about 197 RWHP.
What RWHP do you think I would get out of my old L48 if I rebuild it with the Performer carb and intake and hooker exhaust with a cam similar to the 12499529's and the stock heads and 9.0 CR?
Old Dec 16, 2004 | 01:39 PM
soggybottomboy's Avatar
soggybottomboy
I think you will be much happier with the 330hp 350 HO. Much better heads and if you wanted to add more cam later you can improve on the numbers. You were going to get an intake anyway.
http://www.jegs.com/cgi-bin/ncommerc...27&prmenbr=361
Old Dec 16, 2004 | 01:55 PM
TedH's Avatar
TedH
See my signature for improvements that ultimately rendered my RWHP/RWTQ numbers. Took alot to get there using my tired L48 as a starting point. I started with about 160RWHP after a rebuild that included the intake. pistons, and cam. All other items added/occured after the 160RWHP baseline...
Old Dec 16, 2004 | 01:57 PM
comp's Avatar
comp
Old Dec 16, 2004 | 01:59 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i think that is a real good price it was on the top of my "real" list for crate engines.....figure it will be an additional 100 more HP then you have now.....thats base on my dynoed L48 with 142 hp at the rear wheels
Old Dec 16, 2004 | 02:02 PM
bobs77vet's Avatar
bobs77vet
heres some real numbers
77 L48 auto, advertised 180-185 hp....126 k later with headers, 2 into 1 exhaust with cat, no smog stuff... 142 Hp rear wheel
Old Dec 16, 2004 | 02:12 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
He want's it because of the price, not so much the performance, so it's a perfect choice for him. I say go for it.
Les
Old Dec 16, 2004 | 02:14 PM
TedH's Avatar
TedH
I agree. Good value for the improvement over stock. Wrap the orig engine in plastic and place in corner of garage.
Enjoy!
Old Dec 16, 2004 | 02:26 PM
LFZ's Avatar
LFZ
Les
but he asked what type of real hp numbers to expect...which i took as expecting something of a performance expectation when going with a performer intake and carb. Of course its an engine for the budget buyer, but don't expect any real numbers.
Old Dec 16, 2004 | 02:28 PM
djcwardog's Avatar
djcwardog
Default Shoot for these specs...
http://www.jegs.com/cgi-bin/ncommerc...29&prmenbr=361
I like the ZZ4 with 355 HP and 405 Ft-lbs. Of course it is more than twice the price of your candidate mill. Could you rebuild your stock motor for similar specs without breaking your budget? The main questions is your heads - are they up to the task...? You can pick a cam and pistons for a good price, but if you have lousy heads that will get expensive. I also like the dual-plane RPM Air-Gap as does Hot Rod magazine.
Old Dec 16, 2004 | 03:07 PM
jdmick's Avatar
jdmick
Thanks for the replies. Looking at Bobs77 and TedH's #'s it looks like rebuilding the old L48 just doesn't make sense when you look at $/HP. Getting 200 RWHP apparently requires different heads ($$$). Add that to the the cost of a rebuild you get well over $1600.
The HO 350 also starts to get a little expensive for me. That basically leaves me with the two basic GM engines to choose from.
One more question. Isn't it torque that counts? This is where things seem to get confusing. The base $1400 engine advertises 260 HP and 350 lbft of torque. The upgraded cam engine says 290 HP with only 326 lbft torque. What am I missing here?
page62's Avatar
page62
Not a bad engine for the price. The cam lift numbers are the same as the L82 cam. Replace those 76cc smog heads (later on when you have the money) and this engine would be half decent. Go for it!
Old Dec 16, 2004 | 07:36 PM
AGVI's Avatar
AGVI
true also...
Old Dec 16, 2004 | 08:45 PM
jdmick's Avatar
jdmick
That's right. Price first. Of course I want as much reliable performance as I can afford. Searching some past threads I found these articles about a buildup of the base $1400 engine.
http://www.chevyhiperformance.com/techarticles/46320/
http://www.chevyhiperformance.com/te...326/index.html
I figure with a bigger cam like they installed in part II the $1600 engine with my carb, exhaust, and a Performer intake would be fairly close except for the pocket porting and slight CR increase that added about 26 HP before the cam. Take off about 36 HP after the cam for not having porting done and that engine should put out about 300 HP and maybe 350 lbft of torque. (?) Am I dreaming here?
To How does this engine deal look?
